Best Method To Fix Exterior Window Sills
Posted by chipster_2007 (My Page) on
Tue, May 31, 11 at 0:33
I have some exterior window sills that are badly checked and am not able to replace them at this time. What materials would be the best to use to help extend the life of these sills for as long as possible? Would Bondo work or what other products would you recommend? Thanks
RE: Best Method To Fix Exterior Window Sills
Try the link below to the Old House forum
Here is a link that might be useful: rotted wood repair
hey are only "badly checked" some Minwax Wood Hardener, then some High Performance Wood Filler and a new coat of paint (1 coat primer, two coats of paint) should let them hold up for a while.
If the checking is very bad there is very likely some rot under the surface.
