Thu, Apr 15, 10 at 21:30
| Can someone recommend an attic pulldown ladder that is easy to install? I've seen Louisville, Fakro, Century... I don't have a preference between wood and aluminum, but I'd like to not have to saw the legs/feet to adjust. Thank you. |
- Posted by energy_rater_la (My Page) on Fri, Apr 16, 10 at 12:05
| buy aluminum, a little more costly but you won't have to cut the legs/feet. aluminum will have an adjustable angle. also purchase an attic tent to install in the attic over the stair case if your access is within your living space. this will stop attic air and temps from entering your living space. pull down attic stairs are very leaky, and leak more as time goes on. also it will also add to insulation value at this area. best of luck |
