Roofing Question
walnutcreek (
Mon, Apr 30, 12 at 13:47
| I was somewhat surprised to see that there is no forum dedicated to roofing, so hope it is okay to pose this question here.
I must have the roof replaced on my home. The contractor that I have just about decided to go with plans to use CertainTeed Landmark composite roofing. I believe CertainTeed is a good brand, but would like to know for sure. Would also like to know if the Landmark line is a good one.
Thanks in advance for your responses. |
RE: Roofing Question
| Oh gosh, I, too, was looking for some roofing info. sorry, I can't help you with yours but am also wondering how many layers of shingles you can leave on the roof before you have to strip down to the bare wood. Sorry, hope someone can help you with your quetion, and, wellll, mine too. |
| I read a forum here that Certain Teed was involved in a class action law suit for selling defective shingles. Can anyone out there update me on this law suit? Also, does anyone know what the cost of a square of Certainteed 25 year shingles was in 1997? We replaced ours at that time and they are totally junk after only 15 years. |
| The warranty will be prorated so I do not imagine you would receive much of anything on your claim. Plus roofing shingle companies have so many outs to not warranty a roof. If one shingle in not nailed exactly as specified they will not warranty the roof more than likely. Not trying to discourage you but just do not want you to get your hopes up of a larger payout. |
| Any thoughts on whether CertaiTeed Landmark Designer line is any good. I truly appreciate any advice concerning this matter. |
| In todays age there are really not as many shingle companies as there used to be due to the economy the downturn in houses being built and in advance to material durability. So in my opinion the few companies left including Certainteed and GAF make very good products as long as you gravitate towards the higher end or premium products of which CertainTeed Landmark Designer Series is one. |
| Thank youso much, millworkman. This makes my decision as to which contractor to go to so much easier and greatly helps my peace of mind also. |
| I'm having a new roof put on my house and getting Landmark dimensional shingles. I think I'm using Colonial Slate. Have you played around with the Certainteed web site? You can try out the different colors on different styles of houses. |
| After a month of interviewing roofers and getting a good education, our roof is finally being installed tomorrow (soffits were just build the last 2 days). We went with GAF. Some companies were pushing Certainteed, while more were pushing GAF, though all of them sell both. I was told by our roofer of choice (in business for 35 years and well known in the county) that the two products are pretty much equal. |
| Hi, dedtired. I have played with the Certainteed Website by uploading a photo of my house to it. I had trouble with getting the perpendicular correct, but still got an idea of what colors would look like. I just haven't made up my mind yet. Thanks,debi, for the reassurance. |
| I am sitting here listening to the roofers nail Landmark 30 year shingles to my roof right now. They did the garage and porch yesterday. Looks good. I got Colonial Slate. |
| I met with the contractor Friday morning and decided on the Colonial Slate, which is what dedtired also selected. They should start work in about 2 weeks. I am so glad to have that decision made. Thanks to all of you for your input. |
| The shingles on the roof were replaced this past Saturday. I think the new roof looks great. I do have one question. This past Monday night we had a strong rain storm. I found roof "gravel" all over my back patio and deck. In thr front, I found the "gravel" on the walkway and driveway and on my car. Is this normal? I don't remember that happening on another house on which the roof was replaced. |
| That doesn't sound normal to me. We had a very strong rain storm blow through the day after our new GAF roof was put on in early May and didn't see any signs of granule remnants anywhere. Not knowing how much granules you found around the exterior of the house, it may be possible it was just loose particles from when they laid the roof That sounds like the obvious reason, though I'm no roof expert. Here's a suggestion: Monitor it during the next heavy rainfall to see if there is falling particles again. Also, check your gutters, if possible, between the rain storms to see if there is gravel build up in there. If so, take pics. Should this continue, I'd call the roofing company back. After all, the product has a 50 year or lifetime warranty if it's defective. That's my 2 cents for what it's worth. Good luck. |
| When a roof is first applied you will see some granules as there are definitely some loose ones on the shingle as well as some that become loose from handling and applying them to the roof. If it appears to be an excessive amount or this continues for a month or so you may want to bring the roofer back to take a look or call the supplier. |
| Thank you so much debi and millworkman. As suggested I will monitor this for a month or so. |
| I am finding granules where the downspouts empty. I presume it is from the new shingles and to be expected. No big deal. |
| Is it appropriate to cover holes in roof decking with flashing while roofing???? I had informed the roofers that I thought there were decking boards that would most likely need replaced. He said they were not bad enough and just used flashing to cover the holes. Do I need to push the issue? |
We have Elk (40 yr) shingles since 2001 (before GAF/Elk). Don't be concerned about granules in your gutter. Granules are still coming off. Shingles still look good. Lots of rain in Houston. |
