Craftsman Garage Door Keypad Problem
Posted by dsmlexy (My Page) on
Tue, Apr 8, 08 at 11:02
I also posted this under Garages/Workshops, but I'm desperate for help, so I will post here as well:
I have a Craftsman garage door opener that was installed by a previous owner and lack an owner's manual.
My remote only worked a couple of times after I bought the place, so I've been punching in my code on the keypad to open the door. The door started acting funny - closing, then occasionally re-opening. I changed the keypad code 2 weeks ago and everything has been fine, until today.
I entered my code and the keypad started blinking, usually if I press 'enter' again, the door will open. Today it didn't. I tried re-entering my code, with the same result.
The keypad panel has instructions on how to reset the code and how to set a temporary pin. I tried the temporary pin procedure, but it is difficult to pull off when you can't see if the motor light is blinking.
My car is locked in the garage. (detached garage)
I don't know the model number on the motor, but my remote is model #139.53681B (I only have one)
The keypad has one section that looks like it can be removed - one tiny screw holds it on - I think this is where the battery is? (I don't have a screwdriver small enough to open it)
Ideas on what is wrong with the keypad?
Any suggestions on how to get the door open?
RE: Craftsman Garage Door Keypad Problem
f the only way into your garage is the main garage door I would recommend you call a door technician. They can usually drill a small hole and snare the rope for the manual release. They can then install a keyed release in this hole in case of future problems. They could also repair or replace your opener at the same time.
I have the same problem and got new key pad and it still don't work
