Tue, Apr 14, 09 at 9:20
| I have a 1994 Craftsman garage door opener, chain drive, which will not close. When the wired remote is pushed, the lights flash.
I have replaced the old, corroded door sensors but that did not fix the problem. The green lights on the sensors do not light up. I checked the wires leading to the sensors and they both will conduct current. I checked the sensor contact screws on the unit with a multi-tester and get no reading. Any suggestions on what to check next? |
- Posted by don_1_2006 (My Page) on Tue, Apr 14, 09 at 9:25
| Make sure the wiring is connected correctly. One of the wires from each sensor has a black trace. These must be connected to terminal 3 and the two plain white wires connect to terminal 2. If this is not the problem I would suspect the logic board. |
