| I need to re-set about a dozen 3 inch x 3 inch tiles on a shower floor (after some careful preparation and sanding out old thinset etc.). Can I reuse the old tiles, if I can get most of the old thinset off? I am concerned that since there will always be some residu of the old thinset on the tiles, it might not adhere over the long term. Is this concern justified?
To purchase tiles to match these tiles , I would have to purchase an entire box (10-11 sq. feet). I would appreciate any views. |
| The Old thinset residue will not hurt a thing as long as its not built up to where the tile may set too high. Moisten everything before you reapply the thinset. |
- Posted by measure_twice (My Page) on Tue, Mar 29, 11 at 18:25
| shw001, why did the tiles come loose? Reason I ask, if they loosened by themselves it could be an underlying problem that will happen again. Like, water seeping where it should not. |
| Thanks Don, that's reassuring. Will give it a try Measure Twice, that's a great question! and a mystery I have been wondering about. The installation is 2 years old. About a year ago about 4-5 inches of grout broke out in another location on the same shower floor (no loose tiles), I re-grouted with leftover grout and it still looks great. This new section started with grout cracking in a line about 18 inches long, then the crack turns 90 degrees and goes for a few more inches. only 2 tiles are actually loose to the touch. I suspect bad mixture of thinset or grout in that area. Or maybe some hollow spots in the thinset under the tiles. The cracks have not grown in a couple of months and we use the shower every day. I am expecting the worst that when I start scraping at the grout, about a dozen tiles will come out. Then I will use my ocillating tool to scrape out old thinset, clean up well, and re-set. Thanks again everyone. |
