| I can get the materials to do plaster repair work over wood lathe, but I can't figure out where to get the hair for the base coat (goat, horse or cow body hair).
Any leads on a source for clean/processed hair for plaster? |
| Why would you need that? The current technology in scratch coat material far exceeds the, "hair " technology of years ago. Try Structolite. I don't really want to see anymore bald animals. Ron |
| US Gypsum told me they don't recommend any of their products for wood lathe...... So I'm looking at more traditional technology that has been proven to work for hundreds of years. |
- Posted by manhattan42 (My Page) on Fri, Mar 14, 08 at 17:54
| ron6519 is correct. Horsehair plaster is an inferior technique that never worked well. Modern plaster techniques work much better. You can always apply galvanized lath directly to the wood lath to provide a stong base for the plaster. Or romve the wood lath and install lath rock as a base. Better still may be to cover the entire wall with 1/4" drywall then skim coat over that. But if you insist on using neandethal methods, try contacting a slaughterhouse or rendering firm in your area. |
| Goodness, such antagonistic answers! I'm sorry I asked.... |
- Posted by sombreuil_mongrel (My Page) on Sun, Mar 16, 08 at 11:00
| In the days before standardized, kiln-dried, planed and straightened framing lumber, plaster on lath was the most efficient way to turn very uneven framing into dead-flat walls with great insulating and acoustical properties. If our forefathers had sheetrock and rocklath it would not have done them much good, because the success of those materials is uttery dependent on the uniformity of the framing (to a lesser extent with rocklath, if used as the base of a three-coat job). The older portion of my house has clay/lime/hair basecoat plaster over riven lath nailed on with square nails. There is lime whitewash over it in places, and a soft whitecoat in others. After 150 years it's still serviceable. I don't regard that success as evidence of an inferior technique. The plasterer's technique shows great craftsmanship. Maybe their _technology_ was limited, but their technique was impressive. And technology is _always_ the limiting factor in any venture. Casey |
- Posted by sacto_diane (My Page) on Sun, Mar 16, 08 at 13:08
| Here's a page with some plaster repair how-to. As a general rule, you don't need to use the "hair" in a repair. Using a traditional multi coat process will work well. Diane |
Here is a link that might be useful: Plaster repair tips
| The only reason horse hair was added to plaster was to give it a bit more strength and to use as a filler |
- Posted by sombreuil_mongrel (My Page) on Sun, Mar 23, 08 at 9:52
| Horsehair didn't give it strength, per se, but prevented the scratch coat from cracking as it dried. Any spiderweb cracks in the brown coat would translate into the brittle white coat. I recall seeing somewhere a fiber additive for structolite/gypsolite; when I tried looking for it again, I can't find it! Now, they add chopped fiberglass to concrete to minimize the cracked appearance that the surface can get from drying too fast. Casey |
- Posted by bob_cville (My Page) on Mon, Mar 24, 08 at 14:47
| A friend of mine who runs a plastering business recently married a friend of my wife, who owns and runs the horse-boarding facility where my wife keeps her horses. Hmmmm. Maybe he has an ulterior motive. :-) If Iceman starts inexplicably going bald, I'll know whats up. |
| The stuff you're looking for is called "concrete fiber". You should be able to get it at any concrete yard - I doubt it's available at HDepot/Lowes. It's a fiberglass based product. If you really want to use natural hair, you'd need to screen and wash it yourself. Probably the best place to get hair in the proper, rather short lengths would be a dog groomer, though if you're in a rural area ANYONE with horses can give you all the horsehair you want. Just regular daily grooming makes PILES of the stuff.. |
- Posted by Aaron(hilly11@juno.com) onWed, Dec 29, 10 at 14:04
| I've had a few plaster contractors come out and give estimates on repairing our plaster, and one of them told me I have horse hair plaster. He also said that horse hair plaster contains,or can contain,"ASBESTOS". Is this true? I already started ripping one small wall down and now I'm a little terrified. |
| Just a piece of drywall as the base filler strip. Scrw it to the lath. Use the blue stuff made for plastering over. |
- Posted by sombreuil_mongrel (My Page) on Wed, Dec 29, 10 at 19:05
| For future reference, prepared bundles of horsehair (manes and tails) is available from Virginia Lime Works. Working it into a batch of lime/sand plaster takes a very long time, longer by far than mixing the mud; I think if it wasn't absolutely necessary to insure a good job, the old-timers would not have gone to the considerable trouble to add it. Casey |
| Fiberglass works fine, you just need to be careful during mixing to not break it up to badly. The fiber helps to hold the keys formed by forcing the base coat through the gaps in the lath together. You should also use rough cut wood for lath, not planed. If you have old wood that is badly out of plane, instead of trying to shim sister pieces ox 2x to the sides of the old wood sitting just proud of the lowest spot in the surface. A laser protecting a vertical fan beam can be used to true up the new wood as it is screwed to the sides of the old studs. |
- Posted by Nick(merseybeat1963@yahoo.com) onSun, Mar 27, 11 at 23:01
| Our house's main section is from 1874..the plaster undernieth the white top coat..(base coat) has hair of some type in it and seems lime based...And it almost looks like dirt is mixed in with it.It really crumbles away...and with out that hairy stuff would have failed long ago...(which pretty much has actually). Really this plaster version sucks. The plaster used in our previous 1906 house was better..and the replacement plaster cieling in the kitchen which was done sometime in the 1950's-70 in that house was absolutely the BEST of the lot. In this house they used hair cause the material they used NEEDED it ,it seems. Using structolite...with a touch of cement...over wood lath that is vaccumed & dampened,( putting Plaster Weld a day before at exposed original plaster edges) has worked well for us. But..I usually pre drill & carefully renaill what I can, with very thin short Maze nails.. which is dangerous, as can shake things up. When you have a good dense consistancy of structolite and have applied it (working it upwards)..keying into spaces..After it sets a bit... gently go over it to compact it before scratching lines into it for second base coat. |
| Use a finish nailer for re-attaching lathe. 1 inch long,#16, T-head nails works pretty well. The single quick impact to drive the nail has far less of a chance to disturb the remaining plaster. For small jobs I use a Paslode butane gun, for larger jobs I drag out the compressor. |
- Posted by sombreuil_mongrel (My Page) on Mon, Mar 28, 11 at 18:51
| We have had great luck using a 1/4" crown (pneumatic) stapler for putting up wood lath. If the staples rusted out it would be bad, but they grip the thin wood really well if the staple's oriented across the grain. Before we discovered this we were hand nailing with #4 sinkers, which work, but still could split some lath, and hand nailing is of course vastly slower. We've re-attached two rooms worth of lath so far, and it's quite a grip. Casey |
- Posted by l2iekert(billyriekert@shaw.ca) onTue, Sep 20, 11 at 22:29
| Does anyone have any knowledge of whether or not horse-hair plaster does in fact contain asbestos? |
| "Does anyone have any knowledge of whether or not horse-hair plaster does in fact contain asbestos?" Generally not. Horse hair was cheaper. |
