Grafitti
Posted by bus_driver (My Page) on
Thu, Mar 1, 12 at 16:29
The lower panel of a white-finished aluminum storm door has been attacked with a black felt-tipped marker. The "artist" had some talent. I prefer the factory finish to anything I can apply to cover the marker. What cleaner is likely to remove the most of the marker without damaging the original white finish?
RE: Grafitti
Have you tried orange oil?
RE: Grafitti
denatured alcohol
RE: Grafitti
xylene.
That is the solvent used inmost permanent markers.
Test anything you try on an inconspicuous spot first.
RE: Grafitti
Try anything you have on the shelf after testing on an inconspicuous spot. The colored chemical has to be soluble in something.
