| I have a question about silicone, like the kind you use for kitchen and bath, windows and doors, etc.
Will wet silicone bond with dry silicone? What I mean is, if you do put some silicone down and it dries and then you add more onto it later, will it bond and create a water tight seal? |
| In my experience, it will not bond very well, although it may seem to if you lay down a big bead of it that covers the old stuff. Generally, it's usually better to cut away old caulk -- of any kind -- with a razor blade before re-caulking. What are you trying to do? |
| No. Adding almost any kind of caulk/sealer/etc. over another, even the same type/kind/brand, is not a good practice. Silicon glazes when cured, creating a smooth imprevious finish that resists moisture/dirt/etc. So, if there is a problem with an existing area, remove all the old sealer, clean with alcohol, make sure all moisture and foreign materials are gone, and reapply new material. |
- Posted by ms_minnamouse (My Page) on Mon, Mar 28, 11 at 18:45
| Ok, I called Dow Corning and they said that it will adhere and create a water tight seal. I'll rough up the silicone where I add to it just in case and hope for the best. I'm sealing an aquarium. |
| Well, good luck. If it starts leaking in a while, follow the advice about removing the old stuff. |
