Tue, Mar 20, 12 at 12:45
| Hi,
When my home was built the contractor used a metal I beam in the basement for the main support beam for the house. It has some minor rust. What to you recommend to cover up the rust? Should I just box the beam in, or paint? If I paint what are the prep steps I need to take. Thanks |
| Are you concerned about corrosion or appearance? If the humidity is high enough for corrosion to be a concern, you have other problems too. If humidity is within reasonable levels, the corrosion of the steel should not be a problem. |
| Wire brush the rust away and paint with Rustoleum or similar rust inhibiting paint. |
| It's for appearance. Thank you both for your suggestions. |
- Posted by Jumpilotmdm (My Page) on Mon, Apr 9, 12 at 8:40
| I wouldn't use rustoleum. It's more important what you prime it with than what you finish it with. Using a rusty metal primer will let you finish it with anything. |
