| I live in a 64 year old house at the NC beach with a 6" below grade sand crawlspace. This only leaves about 10" of open space between the sand and the bottom of the floor joists, with the finished floor being about 18" above grade.
Between the occasional hurricane overwash in the '90s and poor ventilation, the floor joists have all dry rotted - causing the old maple wood floor to sag 2" - 3" in the middle of the 20' span. This is only an issue on the oldest, un-remodeled half of the house which comprises two bedrooms and the living room - so there are no plumbing or electrical lines running under the area. 5 years ago I tunneled under the house and tried to shore up the middle of the 20' span with 6"x6"s, but even then some of the dry rotted joists were starting to lose their integrity. I imagine the "money is no object" solution would be to jack up the whole house and set her on pilings, but that's not economically feasible right now.
What about tearing out the old floor and joists (while supporting under the existing walls - which are non load bearing) and bringing in fill dirt to get me above grade and then pouring a 6" concrete slab?
| Have you checked your local building code? Lots of costal areas specific requirements for height or allowing surge to go under the structure. Do you have flood insurance? Your actions will also affect that coverage. Are you going to encase all of your plumbing in concrete? If so, you better replace it all first. You will likely make lots of your electrical cables unaccessible since most of it is probably run from underneath rather than from the attic. How do you feel about that? OK, enough negativity. A slab under the house is far superior to an open space because you don't have all the air leaks to worry about, you lose a huge source of humidity transfer from humid air and you couple the bottom of the house to a moderate temperature mass instead of the highly variable and extreme temperature outside air. Just one more question, was the floor insulated? |
- Posted by hollysprings (My Page) on Thu, Mar 8, 12 at 13:48
| You couldn't pack in dirt there because it couldn't be sufficiently compacted and as previously mentioned, would probably violate storm surge requirements. You think it would be expensive to do piers, just wait until the whole thing falls down and has to be rebuilt! And frankly, with that much rot happening, it would probably be the best solution. The joists cannot be the only thing affected by the moisture issue. The subfloor and framing above it have to be affected as well. |
- Posted by Wetdogsoup (My Page) on Thu, Mar 8, 12 at 14:58
| Thanks for the good input! To answer some of the concerns: 1) Yes it is covered by flood insurance, but because of it's age, the house is "grandfathered" when it comes to having to update to current code regulations. It was built nearly at ground level, long before there were breakaway walls or surge ports built into the lower walls. I'd only have to update to current codes if over 50% of the home's value was being spent on renovation. 2) The areas of the house affected are the two bedrooms and the living room. Thankfully there is no plumbing under these areas and the HVAC and electric is all fed from above. 3) If I were to cut out the floors and joists from above (leaving the load bearing walls along the perimeter of these rooms intact) could I just bring in fill dirt and then rent a vibratory compactor? Cover that with a sheet of polyethelene and then pour the concrete slab over top. (maybe add some rigid foam for insulation before pouring the slab?) Yes, it would be best to lift the old girl up and address all the rot issues, but that's not financially possible right now. |
