Fri, Mar 16, 12 at 9:56
| We will have to put in a drainage pipes on our property which will connect to a seepage pit in front. Does anyone know what this requires and how extensive..is any machinery needed? (need to know for neighbor). Thanks! |
| How deep? You likely need to be well below frost depth. How close to foundations? You can do just about anything by hand with a shovel if you have enough manpower. Even smaller power equipment can make the job go a lot faster and cost less. |
- Posted by hollysprings (My Page) on Fri, Mar 16, 12 at 13:20
| You might need a backhoe, or you might need a trencher. Or you might get by hiring a dozen strong backs with shovels. You haven't provided enough information to be able to tell. Location? Depth? Diameter? |
- Posted by lazypup (lazypup@yahoo.com) on Sun, Mar 18, 12 at 5:49
| How big of an area are you draining and how big is your pit? 1/10 of an inch of rain will produce 2,840gal of water per acre. |
