| All of the neighbors yard's behind my house drain into my yard, how do I correct this?
I've thought a lot about this, and it's likely the reason I have terrible mosquito problems... This "river" collects to this... MOST of the water goes into the tough that was build to prevent the water from hitting the foundation too much. But like you can see, a lot of it gets trapped behind the retaining wall. This is another angle of it coming down the tough. This empties into my side yard. I've thought about putting a large curb along the back of my yard, all draining into one spot (at the top of the yard where most of the water enters), then running 3-4 none perforated drain pipes down my yard, around the side of my house, and down to the street. But I'm open for creative ideas.... Thanks in advance! |
| you need a landscaper. That is not a DIY fix. |
- Posted by GreenDesigns (My Page) on Thu, Mar 22, 12 at 14:09
| You need to talk to the city engineer of your municipality. The water has to go somewhere, and if you are the low point, nothing you do will fix that issue. You need to partner with the engineer in order to see if they will allow you to fix the issue by running some type of pump directly into their stormwater management system. And yes, this is a BIG job not at all DIYable unless you have access to backhoes and dumptrucks AND are a landscape architect. |
| Hmm, I have something like that and I have to fix it too. Has your neighbor made changes recently to cause this? If so, it might be their responsibility to fix this. I would suggest that a pump is the last resort since it is a energy hog and needs maintenance. Regrading and adding subterranean drainage are both options. Landscapers and the city engineers are good sources of information. This might fall into a plumbers' area of expertise. |
