| I'm an electronics tech and yet don't understand, exactly, how all stud detectors work. (1)
The last time I looked at them closely was about 1980. I want something that will be very accurate as to the center of any stud. With the major improvements in all technology I figure it's time to get a quick lesson and recommendations
I have two houses and both have thick walls of plaster and metal lathe over wood frame. Some walls are 6" thick or more.
I want to install into the rafters some screws which should be put exactly in the center of the stud (rafter). Other cases I want to be sure that I've hit the center of studs where shelves might go. I'm just beginning my work on the
(1) At one time the way to detect a 'stud' was to look for the nails in it. So a detector would employ a magnetized needle.
| You can google stud finders and get all the information you need but I doubt any will work with metal lath. Unless you are supporting something very heavy, "hollow wall anchors" will probably be OK in the metal lath. |
| I realize this doesn't answer your question but based on reading I did here, I purchased 10 small rare earth magnets to help me find nails in studs rather than the magnetized needle stud finder. |
| I have yet to find a stud detector that is better than hit or miss through 3/4 inch plaster. Metal lath will only further cause confusion. The detectors are basically measuring the density of what is under the detector. You start the detector on a location that does not have anything in the wall, zero the device, then slide it over the wall. Metal mesh will kill the sensitivity of the detector, as does thick plaster walls. To make matters worse, many old houses with plaster walls do not have the tightly controlled stud spacing required now. Better three studs over 36 inches than 4 studs was the attitude. The detectors work well on 1/2 inch drywall, OK on 5/8, and often fails miserably on 3/4 inch.
