| How do you replace a single glass window pane without making a mess when using "glazing putty"? I prefer the strips to hold glass in like years ago, much easier to use, not available anymore.
Yes, I know, reading instructions would help, but, my DH does not believe in reading instructions or having much in the way of patience or a steady hand at age 82!! We now have a second messy window glass installation that is an eyesore, and it is the first thing you see when opening the front door. The putty stuck to his fingers but not to the metal frame/glass very well. He put the points that help hold the glass in upside down, thought it would be better than the correct way. Now there are sharp points pointing up to rip hands when cleaning the glass. Any tips on how to remedy the situation other than calling a professional to take it out and do it right? Thanks. |
| Read the instructions? |
| Use a putty knife to finish the putty instead of fingers. But, if he will not do it right, hire the pro. |
| Glazing windows is a dying art. Pull the points out and put them in correctly. Roll the glazing compound in you hands to get a long rope and place on the glass. Wet a small putty knife, place at a 30 degree angle and about 1/4" up the glass. Run the knife down the glass. I am sure it will not go easily but if you keep the knife wet and keep going over the area you may end up with an exceptable outcome. |
| Use DAP33 glazing. It needs to be worked to warm it up in cold weather, or kept in a cooler in hot weather for easier application. If you get it to the correct temperature you do not need to wet the putty knife to strike it off cleanly. Make sure there is enough putty at each edge to require striking off. The other thing is to make sure you put a tiny bead on the opening before the glass goes in. |
| If you are not skilled at this it is always better to wet the putty knife. It can't hurt! |
- Posted by sacto_diane (My Page) on Sun, Feb 20, 11 at 14:38
| A picture says a thousand words. I learned some of my window glazing techniques by watch some YouTube videos. They're not always 100% "accurate" but it's better than guessing. Guys that don't like to read instructions can maybe watch a video or 2. Tell your DH it's a sports video. ;-) |
Here is a link that might be useful: How to glaze a window
| Dying art indeed. The surfaces have to be clean. If they're wood, prime them first. Oil paint is best since it retards the inevitable putty dry out. Get a workable handful of the putty and massage/knead it to make it pliable. You want room temps or above. Make a thin snake and apply to all the frame surface, called the "backbed" (probably regional) Place the glass, mushing out the backbed to the edge of the frame. Set the points. Take your handful of putty and use the thumb to place a dollop on the glass/frame, filling the fillet angle. Manipulate the hand to continuously feed putty to the thumb and repeat that step until you've gone around the glass. On large panes you'll need more than one handful. Strike off with a knife (backbed too). If you're sloppy or slow, don't put contaminated putty back into your batch. A scraper using a single-edge razor speeds pane clean up. The job isn't complete 'til you paint, slightly over the putty onto the glass. |
| "If they're wood, prime them first." Or treat them with BLO (boiled Linseed Oil). |
| Thanks everyone. DH is going to try and "fix" the window tomorrow. Will see how it turns out. Our daughters were here today celebrating DH's birthday and gave him a few pointers. Maybe he will listen to them, I know he does not listen to his wife!! |
