Sun, Feb 3, 08 at 18:00
| Can a seal on an Anderson sliding glass door be repaired. The inside seal was pawed by a dog and I would like to get it repaired. If so who do I call or can I do it myself? |
| Is it the seal between the glass panes, or between the glass "unit" and the door. The glass is a unit of two panes with an inert gas between. You cannot fix that yourself, you will need new glass unit. |
| If by seal you mean the weatherstrip, then it can be repaired. Call Andersen's service department (number on the web site) and let them help you - at least with finding the right part. |
- Posted by Paul Johnson(Pjohnson602@comcast.net) onFri, Aug 26, 11 at 17:36
| What kind of glue should I use for putting up new vinyl weather stripping on the door and doorpost? |
