Ceiling paddle fan repair
Posted by ionized (My Page) on
Mon, Feb 11, 13 at 17:47
When the fan is switched on the motor hums, but it does not turn. Is it worth fixing or should I just go and buy a new one? I've never worked on ceiling fans before. I don't know if it might be the motor itself or I might get away with a capacitor.
It is an Emerson CF529W
It looks like this one but the model number is slightly different
http://www.vintageceilingfans.com/emersoncasablancaclassicceilingfanmo delcf529.html
RE: Ceiling paddle fan repair
Replace it.
Scrape the copper.
If you like the fan, I'd try replacing the capacitor. (If it looks half-melted, that's probably the problem)
Finding the correct capacitor, though, might take a bit of research. They're not universal.
"Finding the correct capacitor, though, might take a bit of research. They're not universal."
And often come as a block of multiple values for different fan speeds.
Thanks for responding. fortunately, I have the "installation Instructionns and Renewal Parts Identifications", dated 1980. There is a "capacitor" @ 4 mfd/340V and a "Capacitor, Speed Control". I'll betcha that the latter costs more.
Is a motor likely damaged from being powered on but not started for an extended period?
4 mfd sounds like a run capacitor, not a start capacitor.
The guy's are right: Junk it, these fans are really cheap to replace.
