Sheetrock or plaster
Posted by joeykbasile (My Page) on
Sun, Feb 28, 10 at 13:37
Hi;
I've read the plaster posts.
My room had paneling over plaster. The large finish nails and 100 year old cracks seem daunting to a novice plasterer. I'm not bad at sheetrock compound, but have limited experience with plaster. The Easysand 90 is encouraging. Should I take the time to fix up the plaster or put 1/4" sheetrock over the plaster? I have no intention of removing the plaster and lathing.
I did one small area with patching plaster mixed with sheetrock mud and it looks good, but took time. I don't want to ruin my plaster walls with sheetrock, but need advice on plaster application. Thanks Joey
RE: Sheetrock or plaster
Throw the "patching plaster" away.
It is a horrible product not really suitable for much of anything.
Old finish plaster was a mix of lime putty and gauging plaster. Setting joint compounds are a modern version.
You can skim the surface with Easysand and the work will go much faster with a plasterer's trowel instead of drywall knives.
You want a trowel with a decent handle diameter, like at least 1.5 to 2 inches.
The little 3/4 inch round handles are not worth working with.
When you use the trowel to spread over a large area you rotate your hand slightly to raise the edge of the trowel in the direction of movement.
The trailing edge leaves the surface with a smooth finish.
When you sweep back in the other direction, rotate the trowel to raise the leading edge.
I only do large areas a few times a year and it still takes some time to get back into the correct movements and rhythm of sweeping back and forth to spread the plaster smoothly.
Start in a less visible area like behind a door, or in the wall adjacent to the room entrance.
