Rebuilding portion of exterior wall - should I use vapor barrier?
Posted by tinag333 (My Page) on
Sun, Feb 28, 10 at 13:01
We are in PA and our house is on a slab - no basement. We recently found mold in one of our bedroom walls from faulty flashing. I removed all of drywall and insulation to find that the sheathing was completely rotted through. So now we are looking at the metal siding on one wall about 6.5 feet high by 4 feet wide. Parts of the studs and sill were also rotted so I was going to replace them as well.
Our bedroom gets quite humid during the spring/summer so we run a dehumidifier. Also, in the winter, it gets somewhat chilly (about 60 degrees) in there.
So my question is, while rebuilding this portion of wall, should I install a vapor barrier? Inside the insulation (I was going to use foam board) or outside? There is so much conflicting info on the web and I'm finding arguments for both ways. I don't want to trap moisture inside the wall.
Also, while checking out the sill, I noticed that there is a small area where I can actually see the ground/light from outside. How do I plug that up???
I realize that a professional could better handle this situation but unfortunately, that's not an option.
Thanks,
Tina
RE: Rebuilding portion of exterior wall - should I use vapor barr
Yesssss to vapor barrie and it always goes on the warm side, i.e. under the drywall. As to your last question, I'm confused.Are you talking about the sill or the slab ? You already said that the sill was rotted or are you talking about another area ?
Thank-you! I guess I don't know what I'm looking at. The sill is rotting but not rotted through or anything but when I look between it and the siding, I can see the ground from inside my house. It's hard to explain. Maybe I'll be able to see what's going on more clearly when I rip it out.
