Thu, Feb 3, 11 at 11:58
| I disconnected the wall unit and, so far, I haven't had a "ghost" opening. I also tried the cancel sequence and it did NOT work. Does this have any significance? |
| What kind of remote? The old dip switch type ones have a limited number of combinations and is someone nearby chooses the same settings the door can open. It can also be caused by sensors being not adjusted correctly. |
- Posted by don_1_2006 (My Page) on Thu, Feb 3, 11 at 16:15
| The most common cause of this is the wall control but it can also be staples that have cut through the insulation. |
- Posted by don_1_2006 (My Page) on Thu, Feb 3, 11 at 16:18
| Geno you need to stay with your original post. Now everyone is confused but you. |
