| We had our contractor tear off a drywall fireplace surround that was coming apart. The bricks underneath were damp, which was expected since the previous owner had a lot of ice damming that wasn't taken care of because she was ill. Since living in the house and being alerted to the damming by our next door neighbor, we were able to stave off any major damming and had no additional water over the past 3 years.
The contractors ran heaters and fixed some of the mortar and when the bricks were dry, they painted with a masonry sealer and then BM paint. They started to see some stains come through, so they did use Kilz, as well. However, after 2 coats of kilz and 2 coats of the interior paint, the staining is not any better, in fact it has gotten worse as of today. Is there anything that can be done at this point? Any additional product to try? The fp is painted white...if we went with a darker color, would it hide the stains or would they show up no matter what? Our contractors are aware of the issue and we haven't yet discussed what the fix will be. I just want to gather some other opinions or btdt suggestions before hearing their thoughts. Thanks in advance! |
| If new water stains are present, then new water intrusion is happening. What was done to fix the water damming problem? Look for new roof/chimney water problems. Water intrusion has to be prevented, it cannot be camoflaged. |
- Posted by hollysprings (My Page) on Sat, Feb 25, 12 at 20:08
| Everything you've done is a bandaid on a gushing artery. It doesn't address the real problem at all. You're seeing "water stains" as the problem, when the real problem is water infiltration. I would highly suspect that the chimney was not properly flashed and that you might have some rotten decking and even support members if this has been going on for a while. |
| I appreciate the feedback....I should have written that the water infiltration issue has been addressed at the roof/chimney with repairs. I'm just looking for advice about how to cover the water stains. I've since done some research and perhaps an oil-based or shellac primer should have been used. |
- Posted by mainegrower (My Page) on Sun, Feb 26, 12 at 10:06
| I'm resisting the temptation to say that there is a special circle in you-know-where for people who paint brick work. If you're correct - and there's no reason to believe that you're not - that the water intrusion problems have been eliminated, then the problem was that the bricks were not really dry when the finishes were applied. Bricks can absorb a surprising amount of water. If the surface feels dry to the touch, it does not mean that all the water has evaporated. In addition, running heaters at one level of the house would not have prevented moisture from migrating via capillary action from the bricks above and below. Probably not what you want to hear, but the coatings now in place will prevent rapid evaporation and the stains will keep appearing until all the water is finally gone. You might try Kilz again, making sure that it's not the water based kind, but I'm not optimistic. |
| "they painted with a masonry sealer and then BM paint. They started to see some stains come through, so they did use Kilz, as well. However, after 2 coats of kilz and 2 coats of the interior paint, the staining is not any better, in fact it has gotten worse as of today. " None of these coatings are ging to stop continued moisture migration. If the bricks have a large water load in them, the water will continue to move as both liquid and vapor through the brick towards the heated space. 'Tincture of time' is often the only real 'cure.' |
| mainegrower, I would have loved to keep the brick, but it was not a pretty brick at all. And didn't seem to fit with the rest of the house. But maybe someone else would think differently. :) So, brickeye if there's still moisture, should we just keep it as it is and not apply an oil-based or shellac layer? Will the brick dry through all these new layers of paint? Or are we talking about waiting until the paint inevitably pulls away from the brick (ugh)? |
| Leave it alone for at last a few months. As little coating as possible, You want the moisture to escape, not remain trapped by surface finishes. I cannot tell you how many floors ad plaster walls I have seen ruined after a leak by trying to 'hurry up' and fix the problem. Plaster with the finish layer blown off, floors that look like washboards (first one way, then the other as they are sanded and then finally dry). Not everything is NOW. |
