Mon, Feb 20, 12 at 0:50
| About to buy an NYC co-op apartment, built in the mid 50s. It has steel doorframes. I imagine there are 50 yrs worth of paint on the doorframes (maybe including lead paint). Is it worthwhile having the contractor strip this back to the bare metal before painting? |
- Posted by millworkman (millwork4u@gmail.com) on Mon, Feb 20, 12 at 13:08
| depends on the condition of the paint that is there. If it is in good shape you just want it another color, just have it painted. If the painted surface is in poor shape it would need to be stripped. |
- Posted by stuvwxyz99 (My Page) on Mon, Feb 20, 12 at 22:22
| Thanks. To a layman, what would indicate good shape or lack thereof? Will it be obvious when I look at it? |
- Posted by millworkman (millwork4u@gmail.com) on Tue, Feb 21, 12 at 11:00
| yes, and the finish should be smooth, no visible areas where a previous layer was missing. No flaking of the finish. |
| if it looks like it's got a dozen coats of paint on it, then adding another layer will look the same but with a new color. If there are drips, dirt, and other irregularities and imperfections in the surface then they will bleed through and be seen in the recoat. Options are to sand the exiting smooth or strip completely and prep (sand/prime) the steel and recoat. I'd say there's a 99.9% chance that there is lead paint on the doors. If you opt to sand the existing paint, get a good respirator. IMHO, the dangers of lead paint get grossly exaggerated in the general media, but you don't want to be ingesting it. If it's encapsulated and stable there's really not a problem. Good luck |
- Posted by stuvwxyz99 (My Page) on Thu, Mar 1, 12 at 21:41
| Thanks for the info sdello and millworkman. |
