| Hi, all, this past month i had 1950s slider windows retrofitted with vinyl sliders. Three sliders on the west side of house, and one in the north side.
The west side doesn't have a roof overhang nor gutters (since the overhangs are on the N/S side). Inclement weather hits the west side of the house the most (at least the shakes are asbestos, so that's a relief, toxicity issues notwithstanding.) The newly retrofitted sliders had been inset into raw wood framing, via gas-operated nailer. Here's pic of the exterior of one of the western ones:
Questions: Firstly, do I need to paint ASAP - or is there a grace period of weeks, or months, or years to get the framing painted? Secondly, I have Ben Moore Premium Interior Latex paint [pearl color] in the house. It's difficult to get to the home center 1/2 hour away. I don't have a car, the transportation system is horrible, etc. Would the premium paint intended for interior, passably protect the outside raw wood? Finally, i'd appreciate an online pic showing the best paintbrush for this? (I have plenty of brushes in the house, both bristle & foam ones. Just wanting to know which is optimal for such a job). Thanks! |
| Interior paint is not designed to be as weather resistant as exterior paint, and may also be missing mildewcides to make it keep looking nice. |
| um, does this mean it's totally not advisable? Or could it work for a few years, after which i can worry then? And should i rush to do it? and which brushes? btw, do i need to bother to do anything with the peeling framing that you see surrounding the current raw-wood frame? |
- Posted by Renovator8 (My Page) on Tue, Jan 24, 12 at 19:32
| Scrape off the loose paint and apply a coat of a good acrylic primer with a medium nylon bristle brush. That should be OK for a year but you might as well trim it instead since you will have to do it later anyway. If you leave a project unfinished it usually will never get finished and water will almost certainly get into the wall and eventually cause expensive repairs. |
| thanks - any particular brands and model numbers you recommend? or if paints don't have model numbers, whatever the ID. Should it be a 2" wide or 1" brush? |
| You can buy paint on line and have it sent to you. I would use a 1 inch brush like the Purdy pictured below. |
- Posted by sierraeast (My Page) on Wed, Jan 25, 12 at 9:43
| You should run this by the paint forums and ask the pros over there. I would omit asking about using interior for the exterior though. Even if it was completely protected from the elements directly, it's the moisture levels and temperature changes that interior finishes have problems with. Just not a good idea at all. |
| Thank you both for the tips - I actually just phoned a local place, and was advised against doing anything in such cold weather, but rather to wait for 50 degree minimum weather, and that I should first prime, and then paint. Any comments on that? Also, I have (out in the freezing garage) some cans of varnish, and some Val-Oil I believe one of them is Man O'War varnish. I remember decades ago, attempting to varnish a picnic table outdoors in the hot sun, and it started emitting smoke, so i was terrified. That was old stuff too. |
- Posted by christophern (My Page) on Thu, Jan 26, 12 at 4:17
| Would any of those be OK to use? NO,no,no |
- Posted by Renovator8 (My Page) on Thu, Jan 26, 12 at 8:26
| It should be obvious that interior paint should not be used outdoors and that bare wood needs a primer and that you can't paint below 50 degrees. It's all written on he side of the paint cans. You can use any brush size because it can be turned sideways for such a small job but obviously the smaller ones are cheaper and slower to use. Do not expect paint to seal exterior cracks or joints; it will fail and water is drawn into a wall through tight cracks as if it were under pressure. The detail you show needs trim that is sealed to the window frame and wall, then paint so whatever you use now is only temporary. Why do something more than once? It's always cheaper and easier to fix it right the first time. Dare I tell you that there are low temperature paints that can be used as low as 35 degrees (that is the lowest overnight temperature not the daytime temperature). Such paints are usually only sold by professional supply houses. |
| OK, thanks! So - to ensure we're on the same track - the correct answer is to wait until spring time, and then apply ONE COAT PER WINDOW of latex primer, using a one inch angled brush So would I need a gallon? (for 4 wide windows) BEHR: |
- Posted by sierraeast (My Page) on Mon, Jan 30, 12 at 10:23
| Make sure the windows are flashed out properly. Primer the bare wood you have installed now. Trim out the windows and primer the trim. Caulk and fill fastener holes and finish with two top coats of an exterior acrylic enamel. With all due respect, you should get estimates from a reputable handyman in your area. You will be money ahead in the long run but only if you seek out those with experience and have a good reputation in your area. Ask neighbors, friends, family for reliable, reputable help that they have used in the past and are satisfied with their work. Windows need to be flashed right in order to keep water intrusion/ moisture from gettin in. The caulking is only for cosmetic purposes only. Get someone that knows what they are doing or you will only have continous problems and you will constantly have to re-do your work. |
| A quart will be plenty. |
| Thanks! I'd actually posted a followup a few days ago, which I now see didn't get posted for some reason. First of all - graywings, thanks so much for all your helpful tips. To Sierraeast, and anyone else: Can you please give me a ballpark figure as to what it should cost to get 4 of those windows attended to by a licensed painter? I've never done this before, so have no idea. |
| "by a licensed painter" Painters in many places just operate as a general contractor. There is typically no license just for painting like plumbing or electrical licensing. ook for bonded and insured. |
- Posted by energy_rater_la (My Page) on Sun, Feb 5, 12 at 14:02
| prolly around $100?? just guessing... can't imagine hiring someone for such a small job. to diy: caulk any holes, and where new trim pieces meet use an exterior window and door caulk white or clear give caulk 24 hours to dry. make sure all surfaces to paint are clean and dry. let the kiltz dry..at least 24 hours. then paint with exterior trim paint. let first coat dry and paint again. I'm a Behr paint girl..but any good don't store paints & kiltz where they best of luck. |
- Posted by energy_rater_la (My Page) on Sun, Feb 5, 12 at 14:03
| on caulk, kiltz and paint as to specifics for the brand you choose. |
- Posted by sierraeast (My Page) on Sun, Feb 5, 12 at 19:39
| Priming should always be done before caulk and filling, especially on bare wood projects. |
- Posted by sierraeast (My Page) on Mon, Feb 6, 12 at 10:57
| Hi Jally, Do you currently have any seepage or water leaking at all in their present state? The reason I suggested a reputable handyman is that one who has experience in most all fields will also have the tools to take on this project. To trim out according to your picture, I would bring my portable table saw in order to rip down backing to accept the trim. Also would bring my finish chop saw to clean cut the trims as well as sanders, finish nailers,etc, all tools that a reputable ,experienced handyman would have along with all painting tools. If you are just looking to paint what you have installed and you have no leaking issues, you can easily do this yourself. Get a quart of bullseye zinnzer 123 primer, some dap dynaflex 230 sealant, and a good quart of exterior acrylic enamel and you'll want to put two top coats. Sand and rid any loose debris from all, clean the surfaces well ridding any dusts, primer, then caulk all joints where woods meet using the method mentioned above of cutting a small bead from the tube and as you caulk, moisten your finger and work it smooth into the crevices. Any larger gaps might need a second application as it will shrink a little. Finish off with two top coats of the acrylic. Let all applications dry well each step although you can caulk within a couple of hours of primering if it is fairly warm and dry day out. You might want to wait until it warms up a tad if you are in a colder climate. The brushes mentioned are a good brush for you as well. I prefer a sash brush for all applications, but a good cutting in type brush 1 to 1-1/2" would be easy for you to handle. Purdy makes a good brush, I would recommend the chinex bristled brush. They are pricy but will last you a lifetime if you take care of them. If this is a one time project and you do little painting or not much more in your future, then go with a less expensive nylon bristled brush. Clean often as you go and clean well before storing. |
| Well, I already got an estimate from a very nice guy who's licensed. He said the job should wait until at least March. Here's the sequence he quoted he'd do (I didn't prompt him with suggestions, rather waited to hear his proposal): Four windows for $200. P.S. curious why you state primer should be applied before caulk, whereas he does the caulk first.. He's an older guy, maybe in his 60's and seemed quite experienced. |
| P.P.S. sorry I failed to respond to the Q about seepage. There wasn't seepage that I know of, but then again, they were very old windows, including storm windows. If anything, the sloped-wide windowsill between the inner 1950s window and the storm window might have sometimes been damp if I'd forget to close the storm window when it rained. Nothing too bad that couldn't be mopped up. |
