Sat, Jan 19, 13 at 13:07
| My bathroom is under renovation. I put in a new floor, john and sink. Upon tackling the ceiling, my wife did a great job scraping, in parts, the large plaster swirle ceiling down to the "Green Board" used in bathrooms in the 60-70's. My question is what if anything do I do to prep the green board? And should I mix plaster and apply right over the green board. Or do I use joint compound. We want to replace the scraped parts/patchs with the exsisting plaster swirle |
| Use joint compound. Plaster will harden, and you won't be able to sand it. There is a drywall primer called GARDZ. It is specifically made for drywall that's in bad shape. You may want to use that after you fix the dings. |
