Replacing Foundation on Shed/Cottage
Posted by TooMuchDIY (My Page) on
Wed, Jan 22, 14 at 12:25
We recently bought a brick home built in 1962. It came with the nicest "shed" I have ever seen in the backyard. It's approximately 25x25 and has stairs inside up to the second floor loft. The shed currently has no utilities or sheetrock, but has 4 windows on each floor and some insulation. It's approximately 30 years old and was built by the only other owner of the house who was a carpenter.
Our plan is to turn this shed into a 1 bedroom cottage to rent out for extra income. The problem is that the foundation is a series of 6x6 pressure treated posts presumably on concrete footings and most of them are rotting. I believe the cause of the rot is a combination of the lack of gutters so that the roof water falls directly down to right next to the posts as well as the slight grade of the small yard towards the shed. I realize that these issues will need to be addressed.
The current "crawl space" is VERY tight. On the lowest side it is only an inch or two from the ground and the highest side is a little over a foot. Since I need to run plumbing, I would like to lift the shed when replacing the foundation and have a proper sized crawl space.
Should I replace the posts with new 6x6's and then put up skirting of some type for aesthetics? Or should I use a block foundation? What are the pros and cons of each?
Is lifting this building something I can do with some friends and jacks, or do I need to hire a house moving company?
What other aspects should I be considering? Any guess at the ball-park cost of replacing the foundation?
Thanks in advance for your knowledge and help!
RE: Replacing Foundation on Shed/Cottage
I recommend that you find some reputable contractors in your area and ask them to come out and provide their opinions and an estimate.
I have no experience, but I'm pretty sure you will need permits to rent this unit. The town may require an inspection. I suggest you hire a pro to make sure everything is done to code. Odds are the whole thing was never built or permitted as a "residence" and probably not to code. (not saying it was poorly done, just not to "code")
I will need building, electrical, and plumbing permits. That's not an issue as I just went through that whole process with the renovation on the house. An inspector indicated that there's nothing about the shed that would not be up to code as a livable space except for the rotting foundation and the need for a new roof in the next few years. Obviously, there is no electric or plumbing installed yet, but they will be done to code as well.
You can tell from its design that the carpenter that built it was planning to make it a livable space at some point, but it's like a project he just never finished.
I know some contractors, but most don't have experience with lifting buildings. I tried googling for house moving companies in my area, but only came up with furniture movers.
"You can tell from its design that the carpenter that built it was planning to make it a livable space at some point"
With the water runoff problems, a wood foundation and a one inch ground clearance, I'd come to a different conclusion about his intent. Or, to a different conclusion about his knowledge and ability.
I'd be interested to hear what happens with this project, and whether the ultimate outcome is lift up or knock down and start from scratch.
A building with rotting foundation is resting on a half inch in twelve hillside and you ask .
"Is lifting this building something I can do with some friends and jacks, or do I need to hire a house moving company?"
If you and your friends know how,I see no reason you couldn't do it. The question is like me asking "my friends and I plan to lease a Gulfstream III and tour the world. Should we hire a pilot or can we fly ourselves. If you decide to hire somone,I suggest a foundation leveling company over a moving company unless you want to relocate the building.
Perhaps because it wasn't doable where located. I like Klems analogy " should I hire a pilot to fly the plane ". I'm going to steal that one.
By the time you get a real plan, find a mass of hardwood cribbing, find 2 or 4 steel I beams, rent some hydraulic jacks, rent some real machinery to lift the beams in place, cheaper than feeding a dozen men, actually it a long list, if you don't know what's on that list you will be better off hiring a pilot.
Don't forget a few million dollars in liability insurance, crushing a friend under a building can get expensive.
I don't think you need a house moving company, since they focus on moving a house from one place to another. Assuming you want to jack up the house and replace the foundation, and then set it back down, you need a general contractor with experience in jacking up a building in place.
The length and size of the beams required to raise a 25x25 foot house puts it out of the do-it-yourself category. I've seen it done on some of the home shows and it requires heavy equipment to move the beams and get them under the house.
If the underlying concrete footing is solid, it may also be possible to replace the rotting 6x6 beams a section at a time and only raise the building up enough for clearance to get the 6x6's in and out. However, that will not help with getting space for plumbing. It also won't be fun crawling around at foundation level replacing each section of wood.
6" wide seems small for a perimeter foundation so i would think they would be doubled up to give at least 12" width to set the floor joists. 25 feet is also a wide span for a shed floor, so there should also be a beam or supports to hold up the middle, or the joists should be appropriately sized to span that width. Make sure you have fully evaluated how this shed was built.
Bruce
