| hi folks,
The sitch: 1922 1400sf bungalow with finished 1 1/2 floor/attic dormered living space. Too cold in winter, too hot in summer. Forced air heating has one vent to upper floor which is not very effective due to length of duct from basement. I blew cellulose into the ground floor walls last spring, but this has had little effect on the hot/cold conditions upstairs. I want to retrofit the existing insulation in the triangular side attic spaces [see photo] off the finished dormered space.
Here's an illustration of the existing insulation scenario. The existing fiberglass batting is of unknown year, likely the 1970's, and has many gaps and holes. There is no vapor barrier present.
1. Everything I read (for instance) tells me that either the rafters OR the kneewall should be insulated, depending on whether I want this storage space to be part of the thermal envelope or not. As it stands, both have been insulated [a] and [b]. I'd like to retain the conditioned storage space if possible. Should I remove the kneewall insulation and focus on bolstering up the rafter insulation? 2. I assume I need to insulate the floor of the side attic [c]. I can't remove the rough flooring wood as it's a constituent part of the subfloor of the finished space [e]. Insulating on top of the floor seems pointless - I could potentially saw a hole and spray in foam between the cracks? 3. The venting situation baffles me. Ha. The side attics are not vented behind the fiberglass along the rafters, and there's a hole in the top where it abuts the kneewall, where [a] meets [b]. As far as I can tell there is no continuous vent on roof [d] leading up to the top attic space [g]. The roof of the side attic [b] simply meets the floor [c] with no apparent soffit vents. What to do about this? 4. My location is Cold Zone 1 (Maine), where R49 is recommended for attics. So I'll need a heck of a lot more than the existing R13 - best way to achieve this might be a combo of fiberglass batt with rigid foam boards? Can I perhaps use the boards to create the vented space along the rafters, with fiberglass on top, then a vapor barrier? I don't mind furring out the rafters, etc, if it will let me get the proper amount of R-value in there. I'll stop here and if anyone is so kind as to give me a few tips as I begin, I'd be very grateful. Thank you! |
| To get near the insulation level you want, you would need to spray(have sprayed) foam insulation into the cavities. Furring out everything you would need would be impractical. With the foam insulation, you could first install the baffles from the soffits to the ridge if you wanted. Open the ridge for a continuous vent and install the correct amount of soffit vents to balance the system. It probably wouldn't hurt to install a power vent in a common area to get the super heated air out of the space. I see no reason to have insulation at,"b" and there should be insulation at ,"c" where it's over heated areas. Ron |
- Posted by mightyanvil (My Page) on Mon, Jan 26, 09 at 8:00
| You might try insulating the heating duct. |
- Posted by circuspeanut (My Page) on Mon, Jan 26, 09 at 8:26
| Thank you both. Mightyanvil, I've already insulated the heating duct; it's a long route up to that room from the other side of the basement, and I suspect my old furnace isn't quite powerful enough to really handle it. What puzzles me is the old saw about hot air rising and the top floors being hotter than the ground floors - absolutely not true here. Ron, I will look into how to install soffit vents. Any insights on using the rigid foam board insulation in this application? Barring that, I'll have to wait for my budget to heal before doing the spray foam. |
| I think the highest rated foam boards are polyisocyanurate at R-7 per inch. You would need 2 x 8 framing to achieve close to R-49 all over the attic. You don't have that in the dormers. I guess you could install the boards in the rafter bays and just spray the dormers to get an even insulating envelope. You don't mention the roof rafter size. You'd have to furr them out to get your stated R-49 result( if less then 2x8). You'd also need to build out the knee walls to get an increased R value there. Unless you uniformly do the job throughout the entire space, you'll have excessive heat loss/gain. I'd bring in a HVAC guy to evaluate the furnace and the ductwork. If the area can't be heated by the current setup, the cheapest solution might be those oil filled space heaters. Ron |
- Posted by mightyanvil (My Page) on Mon, Jan 26, 09 at 13:26
| I had a gravity hot air system in my house from 1891. The volume and temperature of the air required to make it work was unbelievable. Modern systems using lower temperature air and small ducts are entirely dependent on fan power. Warm air will rise up stairways but only if they are large and unobstructed and doors are left open. I would have an HVAC specialist look at the system. Insulation can't keep a space warm if it doesn't have sufficient heat in the first place. As far as insulation is concerned, I would suspect the roof/ceiling insulation. |
- Posted by tiger_gardener (My Page) on Mon, Jan 26, 09 at 16:41
| I have a similar situation. i insulated A & B, but have since been told I should have insulated C, not B. However I want to use the floor area for storage. Do I need to rip out the ceiling insulation and put it on the floor? In my house G is also unknown, is blown in insulation my only option if I don't want to tear out the finished ceiling of the living area? |
- Posted by energy_rater_la (My Page) on Mon, Jan 26, 09 at 18:29
| how big (approx) are those attic spaces? |
- Posted by circuspeanut (My Page) on Mon, Jan 26, 09 at 19:41
| Tiger, I'm struggling with that, too: D, G and H are pretty much unknowns, done during the dormer remodel sometime between 1940 and 1970. As Mightyanvil says, I suspect those areas are contributing the most to the hot/cold problem, be it through insufficient insulation or lack of proper venting. This house used to have gravity heat - the floors still have the grate marks - goodness knows how that worked for the original owners in the '20's, since the entire house (save the later attic additions) was uninsulated when I bought it. I salute you Mightyanvil for making that beast liveable. (On the other hand, I once lived on the 7th floor of an ancient Victorian apartment house in East Germany with one coal-burning stove for 6 rooms, and had to lug buckets of coal up all those stairs 2 or 3 times a day. Compared to that, a cold attic ain't so bad ... ) I guess my only option is to rip through the ceiling to take a look (if I can see anything at all besides rafters in my nose), but we just got done re-plastering and painting the entire finished attic space. Ah well. I wonder the same thing about blow-in up top, Tiger. I installed blown-in cellulose in the walls of the entire house, but am hesitant to blow anything (foam, fiber or cellulose) up into the top roof spaces D and H lest I fill any kind of ventilation baffles up there. I don't see a ridge vent or eyebrow vents anywhere - what are the chances there's even any ventilation at all? Does it even matter for such small enclosed roof space? Is it roasting in the summer more from no ventilation or from inadequate insulation? I too want to save my side attic spaces for conditioned storage, because it's about the only storage space in the whole bungalow. Energy_rater, my attic runs the entire breadth and width of the house, 24' x 36', and is completely finished save for these two triangular side corners that are roughly 9'x8' each. |
- Posted by energy_rater_la (My Page) on Fri, Jan 30, 09 at 21:02
| You are on the right track in determining where to locate your thermal barrier. if you didn't want to use these spaces you would insulate and seal the knee walls and floor (sorry..a & c )and make that the thermal barrier. Since you want to use the floor space then you have to move the thermal barrier to the roofline. I can see that you would need to insulate c..and think that this has to do with some of the comfort issues. that you can not access c makes it more of an issue. Even if you used spray foam insulation @ R-7 per inch I would take up sections of the floor and see what you have to work with. You could cut out sections and replace Have you thought about products for diy like tiger foam? The benefit to foams is that they eliminate air movement. There are climate specific issues with vapor barriers for I'm curious about the fiberglass batts on the roofline. And one last thing..you could make an attic hatch to take Best of luck. You seem determined to get this right, and |
