| we're getting close to remodeling the kitchen addition and i want to add an unfinished second story space above it for future use.
besides the extra labor hours, what else should i count on for cost? the addition can have cathedral ceilings, but two storys' worth will be pricey as heck to heat in the northeast! as i see it the roof will be the same; same trusses,same steel roofing, etc. i'll need studs to hold up the second story at least, maybe a ceiling for the downstairs for heat retention. also extra siding and insulation. i hope sheetrock can wait. i know i can cut in windows, stairs, etc. at a later date if i plan well. it should be more cost effective to do it this way than to wait ten years and take the roof off in order to add the second story. what am i missing? |
- Posted by wi-sailorgirl (My Page) on Wed, Nov 10, 10 at 16:21
| Hmmm ... i'm wondering if it really is more cost effective to do this now than then? You'll be heating and possibly cooling unused space for 10 years, not to mention paying taxes on it. Not to mention, how is your house going to look with an addition with no windows, etc. in it for the next decade? I think it might be minimally more economical to do it now, but 10 years down the road is a long time to sit with it. What if you change your mind about what you want up there? What if you need/decide to sell your house which would be essentially only partly finished? |
| I would expect you would be best served by at least doing rough-in electrical and windows to code for a bedroom |
- Posted by staceyneil (My Page) on Fri, Nov 19, 10 at 9:24
| We considered doing just this. However, our plan was a 1-year, not a 10-year, to finish the second floor. I DO agree with the previous posters that you should do windows and rough plumbing electrical. Our plan: we'd figured out the basic layout of the upstairs. (You'll probably need some bearing walls in the interior, no? So figure out where they will be and what the room layout will be.) it'll certainly be easier to have a complete plan of the upstairs before starting, so you'll know where the stair will come down, and they builders will frame in the opening for the stairwell into the floor, etc. Personally I think I'd have the stairs done now and just have a closed door at the top... Our plan was: So, we'd have a finished downstairs, and a finished exterior. The stairway to the second floor would be sealed/closed with a door. Upstairs, the floor would be plywood subfloor, the interior walls just studs with plumbing and electrical rough-ins coming up through the sole plates but not going anywhere, and the exterior walls insulated and vapor-barriered. I'm not sure I'd want to leave it like that for 10 years, though! What if circumstances changed and you had to sell the house or something? You'd have an empty shell. And wi-sailorgirl's point about paying taxes is a good one. In my town that add'l living space would add a hefty chunk to the annual taxes :( I guess an in-between solution might be to do the careful plans for the second floor now, and run the plumbing/electrical in the downstairs walls, and make sure your architect/builder knows that you intend to "pop the top" at a later date so that construction details can be planned to facilitate that later. |
