JOIN NOW LOG IN
oil-based primer on brick?
Posted by arnold4321 (My Page) on
Wed, Nov 4, 09 at 15:21
I am gutting a basement to remove moldy drywall. I'm also removing studs... taking it down to the bare masonry and joists. My mold inspector suggested I do this gutting and that I follow up by cleaning everything and then painting everything (masonry, joists, outsides of ducts) with oil-based Kilz.
I read somewhere that masonry is supposed to breathe, and for that reason you shouldn't paint it with oil-based primer or paint. Is that right?
I think his rationale for the Kilz suggestion was to provide clean surfaces where mold is a little less likely to take hold, to immobilize any remaining spores and to provide some water-proofing for the masonry. He stressed that I should use oil-based Kilz. (Needless to say, he also recommended a dehumidifier.)
Aside from breathability of the masonry, I'm also wondering about VOCs. Clearly the oil-based Kilz is high-VOC stuff, but I'm wondering if that's much of an issue after it dries. My inspector said it is high-VOC but that after a couple of days, it's not emitting VOCs anymore. This is a basement area that will serve only for storage, not as a living space, but air from the space will make its way upstairs via the HVAC, so I don't want long-term off-gassing.
-Ryan
RE: oil-based primer on brick?
Kilz is a primer sealer that can be used on brick. However, I would not use it on the portion of the wall that is above grade as that is where there will be a vapour drive to the interior during the summer. If the vapour is stopped at the interior basement surface of the brick it will cause spalling.
thanks. what should I use above grade?
I'm not even sure that anything should be applied to the brick below grade. EPA docs and Inspectapedia don't mention the use of coatings after mold has been removed. Instead, they emphasize keeping water away from affected surfaces and basement interiors, so it doesn't reactivate mould spores.
Here is a link that might be useful: How to Seal Basement Floors & Foundation Walls Against Water & Moisture
