Ceramic Tile - install & grout same day
canada03
17 years ago
Featured Answer
Sort by:Oldest
Comments (11)
ttfweb
17 years agospanky67
17 years agoRelated Professionals
Clute Kitchen & Bathroom Designers · Ocala Kitchen & Bathroom Designers · Rochester Kitchen & Bathroom Remodelers · Glenn Heights Kitchen & Bathroom Remodelers · Ridgefield Park Kitchen & Bathroom Remodelers · Burlington General Contractors · Chicago Ridge General Contractors · Enfield General Contractors · Fairview General Contractors · Jamestown General Contractors · Jeffersonville General Contractors · Mount Laurel General Contractors · Noblesville General Contractors · Waianae General Contractors · Waipahu General Contractorsphilmont_2006
17 years agojohn_pcnet_com
13 years agoLindola
9 years agoJoseph Corlett, LLC
9 years agoloves2read
9 years agopremalini79
8 years agoJoseph Corlett, LLC
8 years agoUser
8 years agolast modified: 8 years ago
KITCHEN BACKSPLASHESHow to Install a Tile Backsplash
If you've got a steady hand, a few easy-to-find supplies and patience, you can install a tile backsplash in a kitchen or bathroom
Full StoryREMODELING GUIDESContractor Tips: How to Install Tile
Before you pick up a single tile, pull from these tips for expert results
Full StoryTILE6 Questions to Answer Before You Install Tile Flooring
Considering these things before tackling your floors can get you a better result
Full StoryBATHROOM DESIGNHow to Match Tile Heights for a Perfect Installation
Irregular tile heights can mar the look of your bathroom. Here's how to counter the differences
Full StoryREMODELING GUIDESFinishing Touches: Pro Tricks for Installing Fixtures in Your Tile
Cracked tile, broken drill bits and sloppy-looking fixture installations? Not when you follow these pro tips
Full StoryBATHROOM DESIGNHow to Install a Toilet in an Hour
Putting a new commode in a bathroom or powder room yourself saves plumber fees, and it's less scary than you might expect
Full StoryBATHROOM DESIGNShould You Install a Urinal at Home?
Wall-mounted pit stops are handy in more than just man caves — and they can look better than you might think
Full StoryREMODELING GUIDESGet Stone and Ceramic Surfaces Super Clean
Keep your kitchen or bathroom looking as good as on installation day with the right cleaning methods for counters and tiles
Full StoryTILEEpoxy vs. Cement Grout — What's the Difference?
Grout is grout, right? Nope. Cement and epoxy versions have different appearances, durability and rules of installation
Full StoryREMODELING GUIDESRanch House Remodel: Installing the Interior Finishes
Renovation Diary, Part 5: Check in on a Florida remodel as the bamboo flooring is laid, the bathroom tiles are set and more
bill_vincent
