plywood exterior siding
Posted by timj-in-tn (My Page) on Fri, Oct 16, 09 at 22:08
| I have a house I'm rehabbing that the exterior is in good shape except the prior owner had a window a/c through the wall right next to the front door. I need to replace 2 pieces of 4'x8' 3/8" thick textured reverse board and batten siding with 12" O.C. 1" wide grooves. Everything I'm finding now is 8" O.C. w/ narrow grooves. I've tried everywhere I can think of and internet search. Does anyone know of a source that still makes this siding. It was common when this house was built back in the 70's. Thanks |
RE: plywood exterior siding
| It's called "Texture 1-11 (T1-11) plywood siding". Any lumberyard should be able to get it for you. Avoid the OSB version. |
