JOIN NOW LOG IN
Penetrating a concrete floor...with radiant heat?
Posted by kudzu9 (My Page) on
Sun, Oct 4, 09 at 16:51
I have a 20' X 20' room that is finished and plumbed in one corner for a bathroom. I'm going to put a toilet, sink, and shower in that corner in about an 8' X 8' space. The room is tall: 9' high walls and sloped ceilings with a 16' peak down the middle. I'm not planning on running the new walls up to the sloped ceiling; they'll be 8' high and have a flat, interior ceiling. (Imagine an 8' cube planted in the corner of the room.)
I'm experienced with framing, but the studio sits on a concrete slab that has radiant heating tubes embedded in it and I'm reluctant to punch into the floor to mechanically fasten down the bottom plates of the two new walls. With my luck, I'd be sure to penetrate one of the tubes!
Is a construction adhesive adequate for the job of affixing the bottom plates to the slab? Or does someone have a better suggestion? I thought about locating the radiant heating tubes with an infrared imager, but figured it would be expensive.
RE: Penetrating a concrete floor...with radiant heat?
I have seen construction adhesive (Liquid Nails) fail. I am no longer impressed with it - but I do still use it, and another brand.
Mechanical fasteners are required for a good wall.
It would be EXTRMELY unwise to just fasten down the bottom plates, without knowing where the tubes are... Fixing the floor heat would be mucho dollars.
See if you can find out who did the floor. Maybe they have pictures or a layout plan.
Otherwise - your idea of an infrared imager seems excellent. Or possibly a plumber might be able to help you out... You think imaging is expensive... how much to fix the floor?? after you kill the heat? So your first inclination is best. Find out first where they are...
What could go wrong by using only adhesive for such a small room, esp. if you tie the wall corners together? I would think that as long as the corners are securely joined, and it's tied into the existing house walls, it's not going to move at all. Is this an earthquake zone or something?
The polyurethane structural adhesives are far better than liquid nails.
An interior non-weight bearing wall with a corner and solidly attached to the existing walls should not need that much fastening.
If it makes you feel better, use double top and bottom plates and some Simpson hardware.
In a home I built with a basement hydronic system, the plates for the basement walls were ramset with 1/2" penetration. But I knew the PEX was set near the bottom of 5" of concrete.
Flying blind, stick to adhesives on the floor.
Thanks, everyone. Brickeyee: I think, if I incorporate your ideas, I'll be comfortable with the result.
