Should I get a permit for a basement bathroom?
Posted by mrmichaeljmoore (My Page) on Mon, Oct 12, 09 at 16:01
We are planning on haveing a full bath (stall shower, toilet and sink) installed in our basement.
The basement is already finished, we would just be adding the bathroom.
NOTE: This is not a DIY project. Work will be done by licensed plumbers, electricians, etc.
A friend of mine owns a landscaping design business and in the off-season does contracting on the side. He onws rental properties, flip houses. He uses licensed plumbers and elecltricians for all his work. I've seen his work; it's top shelf stuff.
Now, to the dilemma......
My friend says I should do the bathroom without getting a permit.
He says the permit process is a huge PITA for my town (he would know because he lives in my town too). Plus, he said my taxes would go up.
I asked him, "what if I go to sell, what to I do?"
He said claim ignorance. Tell the inspector/realtor, etc. that the contractor said he got all the permits. He said most folks won't even ask about permits if the work looks done good and right. It is when the work looks like a hack job is when people start to ask questions.
He said we would take pictures of all the work as we went along to show any inspector if the issue came up.
He said if I had to pay a fine at the time of sale, it would be less than the increase in taxes I would've paid.
So, what does everyone think?
If I was doing this myself, I would definitely get a permit. But since all the work will be done by licensed guys (and presumably up to code) why not take the bit of risk and skip the permits?
thanks for the input.
mm |
RE: Should I get a permit for a basement bathroom?
| You're adding drains, so yes, your taxes go up, but you get peace of mind for drain work, which is not to be messed with. You should also worry about "what if it's not done right" when it's a job like this. Do you know precisely how the work needs to be done? There's too much temptation to miss, overlook or alter something important. When I finished our basement and added a bathroom, I pulled a permit for the plumbing. I recall the challenges our very experienced plumber had when he tied the drains into what was a very tight space in the floor with the stack nearby. He did a nice job, but there were a couple real challenges that slowed him down and he was against the clock in his head. I was very glad to know there was an inspection forthcoming, which added incentive to get it done (and tested) properly, no matter what. That plumber also tried to install our shower pan on a sloped floor ("It should be fine....", he said), but had to put the kaibosh on that idea real quick. |
| I think you know what the right answer is: get a permit. I may not get a permit when I am, say, putting in one new electrical outlet, but when it comes to something where there is remodeling, where things can go wrong, and where I would have to lie on the disclosure form when I sell, I get a permit. Your taxes are not going to go up that much from such a small project. |
| "Work will be done by licensed plumbers, electricians, etc." The plumber and electrician will be required to get their own individual trade permits. Why would they risk a run-in with the building department to do you a favor? The issue is mot likely to be decided by you unless these people are really hard up for work. |
| Whether or not you will need permits to install this bathroom and whether or not your taxes will increase as a result depends entirely upon your location. In my state, residential alterations and repairs are EXEMPT from permit, and do not increase one's tax liability EVER. Call your code enforcement office and ask what you must do to comply with your local building code. If you need permits and inspections...GET THEM. If you don't...BE RELIEVED and build on.... |
| Locally, we can get a homeowners permit to do something like that. Much cheaper than 'professional' permits. The work still has to pass the same inspection, just the permit process is streamlined. The gotcha in code departments and permits is that in most jurisdictions, if a non permitted job is discovered, the law covers tearing out the work to allow whatever inspections are necessary and adding a fine on top of that. As a rule, checking with the codes office and following their procedures can be almost painless in many cases. Except for the fees, of course. |
| Between 20-30 years ago my dad put in a basement bathroom in basement, finished basement, built a porch and a large shed in backyard with cement blocks/poured cement floor. He never got a permit. He did have handyman build the porch. The only thing that happened when the inspector came around years after these things were done they noted the improvements and their taxes went up. He is still in the same house so selling it isn't an issue. I suppose an inspector may find "issues" if he were to sell but it's not an issue for now. He lives in a first ring suburb of a Major city, not out in a rural area where things are more slack. Yes, you should probably have a permit but...... |
| But since all the work will be done by licensed guys (and presumably up to code) why not take the bit of risk and skip the permits? I'm not sure why upstanding professionals would want to skip the permit, they have too much to loose. Depending on local law penalties could includes fines and loss of a business license. While permits can be a pita why would anyone wanting to continue doing business in that town risk pissing off the folks who issue permits and do inspections. An inspector with an ax to grind can really screw up a job. |
