| I found this product on the web called "Creative Crown." It is a foam crown moulding that is glued in place with "liquid nails" glue. The corners are premade so there is very little work involved. You measure the corner angle and order it from them. Not sure how it would look or hold up compared to MDF. Would love to hear from those of you with some experience with Crown Moulding...if you have heard anything about foam crown in general, and this product in particular.
Thanks for your help |
Here is a link that might be useful: creative crown
| Haven't heard of this particular brand but I've seen foam crown used. Obviously you wouldn't want to use it anyplace where it could get hit, which is why I've only seen it used as crown. That said, to me it's indistinguishable from other painted crown. |
| ventupete, thanks for the advice. Do you see any disadvantages to using the foam crown, such as damaging the walls if you ever took it down? It sure is tempting to put it up, would be so much easier and less expensive. |
- Posted by mikden (mikden@cox.net) on Mon, Oct 3, 05 at 22:30
| The Villa Deco brand of crown molding is the best foam crown molding to use. It is made from hard foam (styrofoam) and it goes up with caulking. Very easy. Hard to find. website is www.villadecousa.com |
Here is a link that might be useful: Villa Deco USA
| Villa Deco is a quality product (made in Germany) and so far they have distributors in CA, NY, and NJ, but they will ship anywhere. Free samples can be ordered at their new website: www.sosimplecrown.com. |
| I've used Focal Point crown moulding from HD, http://www.focalpointap.com , a composite that is glued up. Looks as good as painted wood crown. |
| If its going to be painted anyway, I see no point wasting good wood on it. The foam will look as nice, last as long, cost far less. |
- Posted by randymeyer (My Page) on Sun, Feb 4, 07 at 16:59
| Life is too short to use inferior materials. MDF looks like MDF. If you can't tell the difference, go with the foam. |
| I found sosimplecrown on this website and used the product in my living room. Great product, easy, people are very helpful. They did some specialty cuts for us (bay window) no charge. One problem, looks so good the wife wants to do the Master bedroom next. |
| I just put Creative Crown molding in my living room and it looks like wood. They are very nice people to deal with and it was pretty easy for a 5'2" woman to put up alone. It was more work than it seemed, but definitely worth it, especially at 78 cents per foot for 3 1/2 inch molding!! I'm going to do more. Everyone who sees it can't believe it's not wood and I LOVE it. |
- Posted by brutuses (2many@cox.net) on Fri, Dec 28, 07 at 7:46
| cinbun, could you please post a photo so we can see your handy work? Thanks |
| Foam is easier to work with than either wood or MDF if you do not have experience with wood. MDF chips rather easily, making sharp angles problematic. As for the removal and wall damage, how many times does one remove crown molding and not do more extensive reworking? Use the foam. |
- Posted by texaspanhandler (My Page) on Sun, Dec 30, 07 at 0:12
| Would like to see pictures, too. Am thinking about using the Creative Crown. DL |
| I posted a picture of a corner of the living room with the crown up, but it doesn't seem to be on my page. |
| I have not used them specifically, is that the foam stuff? I have always stood by the fact that real hardwood is simply the best material to use. It looks better, but of course requires a bit more to install. Also, I found a blog that talks about tip just like this. Good tips so far for beginners. |
Here is a link that might be useful: How To Crown Molding
- Posted by adrienne(14aww@gmail.com) onWed, Feb 16, 11 at 6:15
| I thought crown moulding is all about wood works but thanks for this. It widen my horizon. |
Here is a link that might be useful: Crown Moulding
| Foam looks like foam. What if it's skim coated with drywall mud before painting? Just a thought. I only use plaster moulding as buyers will sneer at any imitations--even if they're fooled by it. (Probably the same people who don't realize that faux finish marble is often as expensive as actual marble.) |
| "What if it's skim coated with drywall mud before painting? " You will round over edges and destroy and detail. It will look even worse. The chief problem with foam is the lack of the sharp corners that you get with wood. Even MDF tend to have problems with sharp corners. |
- Posted by Scott(scott@getoutnow.com) onTue, Aug 2, 11 at 18:41
| I couldn't believe that foam crown molding could look as good as wood, but it does! Even on 8 foot ceilings you cannot tell the difference if you do a good job painting it. I bought Creative Crown Molding for two rooms and love it so much we are going to do two more! It's easier to work with, it's cheaper and it looks great. |
- Posted by garden_person (My Page) on Tue, Jan 8, 13 at 20:43
| Thought I'd give foam crown molding a shot, after hearing users recommend it. Still very undecided. The cost of $2.00 per linear foot is comparable to many mdf and polystyrene molding. Plus to ship a package containing So to do a 10 x 13 room... cost of materials $200.00 Creative Crown WAS selling on their website www.creativecrown.com but now redirects purchasers to two I ordered corners... thinking they were corner BLOCKS. Silly me.. all creative crown did was miter 8 pieces to make The quality of material left a lot to be desired. Yes this is foam cell, like the stuff used for packaging. I had to The first coat of water based primer showed ALL of the imperfections of which there were MANY. These pieces were not pristine, each had small dents, gouges. high spots which require sanding down or filling in. These pieces are NOT ready to install out of the box unless as a homeowner you don't take pride in your work. And if I had to put this up for a client... I wouldn't !!! Haven't put them up yet, so can't tell how they will look or if the seams can be concealed. I'll update this post as Definitely NOT an alternative to wood or polystyrene. This IS lightweight, and go up with construction adhesive. Which basically says... YOU"VE RUINED YOUR CEILING IF YOU HAVE TO TAKE DOWN A BROKEN PIECE OR DECIDE TO GO WITH A DIFFERENT LOOK. Wood and polystyrene go up with nails and fasteners.. easy Don't hit it with a broom handle when dusting your ceiling. Don't use oil-based primers, paints or sprays. Thankfully I only purchased enough for one room and will look into the more traditional methods for all the other rooms. |
- Posted by garden_person (My Page) on Fri, Jan 11, 13 at 0:12
| Day two and the nightmare continues. I would highly recommend AGAINST using this product especially if you are a contractor working on a clients house. If you have a small informal room and use a simple pattern Problem #1 butting two seams together... and one piece of molding is LARGER than the other one by almost 3/16 of an inch... it looks like almost 3 different batches of molding are here... none match. There is a noticeable Problem #2 The DVD showed CORNER BLOCKS. Instead they ship SHORT PIECES which are mitered. This adds TWO ADDITIONAL SEAMS TO EVERY WALL. CCM13 Santa Fe is a raised intricate pattern, seams are difficult to match up. Problem #3 This stuff is super easy to dent. Installation instructions say " Lay a bead of construction adhesive about the thickness of a pencil along the edge". TWO problems here.... pushing the piece up against the wall with A few nice things to say... you can trim this with a razor Well the molding is up on the wall... and I've started spackling which takes 1 to 5 hours to dry before recoating or painting. Because of the intricate pattern " Sunflowers and Vines a.k.a. 'Santa Fe" I loaded each seam After rechecking the website.. Creative Crown no longer carries ANY of the Villa Deco moulding.. looks like they completely got rid of their product line. I wonder why ?? So my final opinion... This is a product that belongs on Saturday afternoon info-mercials along with george foreman grills and electric hot dog cookers. It COULD be useful for My fallback position ?? If after spackling, sanding and painting it still looks terrible then I'll cut through the
