Thu, Sep 15, 11 at 4:09
| I need help! remodeling a room
almost finished but we just realized that 1 door frame is warped on the side where the knob is. it bows out in the center so the door knob bolt won't hit the striker plate. its too late to redo it, so does anyone know if any companies make an extra long (maybe 3/ 8 longer than normal) bolt? or spacers for the strike plate? I could make a spacer, but I thought maybe someone might make one a little prettier than I could make LOL. I would very much prefer a long bolt as it wouldn't be noticeable like a spaced out plate. I've looked around and can't find anything, I hope someone here can help. thanks! can you make the bolt from a deadbolt work with a regular knob? if so that would be OK, it's just a closet door. |
- Posted by mike_kaiser (My Page) on Thu, Sep 15, 11 at 7:36
| Why not just pull off the trim and shim the jamb so that it's flat? |
| nobody makes something like that because nobody would do that. and i agree with mike its the easiest fix. if you have 2 3/8 back set and get 2 3/4 backset bolt and try to get it to work but it still would look like ?hit. |
