| Out of four of our quotes for new siding, two have the foam backed insulation built right into the siding and the others would lay the insulation first and then put siding over that.
Opinions on this? Foam backed seems more sturdy and less likely to warp, but I've heard it doesn't make much of a difference in terms of energy saved. Thanks!! -Sarah |
| When I had my roof leak repair, the roofing contractor also suggest to remodel the siding of our house. We went for backed foam which is sturdy and not likely to warp. Bella |
Here is a link that might be useful: roof leak repair
- Posted by energy_rater_la (My Page) on Sat, Jul 28, 12 at 11:15
| from an efficiency pov put the foam board on the exerior of the walls. tape all seams. put regular vinyl on top. little strips of foam board do little we have a home improvement company locally I've heard of folks that bought into the scam put the foam where it works. best of luck. |
| I researched the foam backed siding extensively. My conclusion was that while it may be sturdier than plain vinyl, its efficacy as an insulator is dubious. Without lapped or taped seams air will infiltrate and compromise the insulation. You also have to be careful about moisture management. Some foam backed vinyl has ridges and channels to drain water, but many do not. I chose instead to sheath my house with Zipsystem r6 insulated panels which are taped at the seams and have an integrated water and air barrier. On top of that we're installing a 3d polymer rainscreen and fiber cement siding. No housewrap required. |
