Advise on Dead Bolt Lock on entry Door
Posted by cruzinpattis (My Page) on
Tue, Jul 29, 14 at 10:05
I just had a new entry door installed with a deadbolt lock.
I am wondering if it was installed correctly.
Problem is when I close or open the door I need to pull the door in hard using the handset with one hand and the other to lock or unlock it.
Is this normal????
RE: Advise on Dead Bolt Lock on entry Door
Nope.
Probably due to new or improperly installed weatherstripping or perhaps a warped door which should be easy to determine.
Could also need a hinge adjustment. Look to see if the gaps around the door are even; ie if the door is sitting squarely in the frame.
A correct installation should have resulted in a smooth, seamless operation.
An interactive mortice lock would have eliminated this problem.
There is no excuse or absolution, for poor workmanship.
Door is not installed properly I would almost guarantee. Sounds like it is not plumb or square. What are the reveals like on each side? Is the gap along the top even? Was this a prehung or a new door in an existing frame? Wood door, fiberglass door, steel door?
The door is pre-hung fiberglass.
The frame is perfectly level.
The door is just slightly off.
Making the reveal look off by 1/8th of an inch.
Is it plumb, square? Reveal being off can be from any of the three.....
