Sun, Mar 14, 10 at 18:02
| If i wanted to remove the old drywall in my unit do run the cable lines behind the wall could I not just re drywall over the existing framing? |
| Sure, if you are willing to demolish the old drywall and install new drywall. |
| You do not need to remove all the drywall, just enough to drill through the studs and pull the cable. Patching is rather easy after a little practice. The only real 'gotcha' is if the wall is textured. |
- Posted by drywall_diy_guy (My Page) on Sun, Mar 14, 10 at 21:53
| You can cut out a panel about a foot or so wide for access. Then replace that panel with a patch after you are done running wire through. It is very similar to the procedure detailed in the link below. |
Here is a link that might be useful: Drywall Replacement
| If you take out the entire wall (or partial) add insulation in none exists. |
| " in my unit " - do you own an apartment building or are you renting a unit? If you are a renter, I assume your landlord would have something to say about this. |
