demountable hinges on cabinet doors
Posted by chloe45 (My Page) on
Mon, Feb 18, 13 at 20:16
I have demountable hinges on my white cupboards which means the hinge is exposed and gives a very busy look.
I'd like to switch to a hidden hinge. The man at the hardware store said it was possible but that it was very expensive.
Has anyone had any experience doing this?
RE: demountable hinges on cabinet doors
All hinges are "demountable."
Conventional hinges are available in two configurations, flush overlay and inset. Changing to a hidden hinge requires patching of the screw holes.
Which type do you presently have?
This is what I have.
there is a T slot in the base of the cabinet ad and a slot in
the side of the door
No screws into the face of the cabinet.
Has anyone converted from this style to a concealed hinge
Double Demountable 1/2" Overlay Hinge
Your next step is to select a hinge you want to install.
As a simple explanation, lets say BLUM, as a for-instance.
There are two choices; 1. Relocate the hinges, remove the doors and have the doors drilled and prepped by a local cabinet shop, purchase the frame jig, drill the face frames and set the hinges. 2. Plug the doors and face frame and proceed as in #1.
Thanks. I'll call around. I have a lot of doors. May be pretty expensive
The doors are not partially recessed, right? (if they are, you need to id that when you replace the hinges.
With the doors closed, what is the overlay measurement (sideways)? Looks like 3/4" or 1" maybe? Once you have determined that, you want to buy hinges with the same overlay (and other dimension, if they are recessed). If you're not a novice, you can buy a forstner bit and bore the holes yourself (carefully). Or you can remove the doors (mark and number them with tape), then take them to cabinet shop (call first to arrange this, or call a hardwood supplier and ask for a reference) and have them bore the holes for you (not a bad idea, btw).
Then install the hinges on the doors. Finally, install the doors to the frames. Pre-drill all holes.
the doors are overlay , 1/2 inch
