| Has anyone tried it? We are removing alll the wallcovering in our home and so far got the bathrooms finished with little or not trouble at all removing the wallcovering. Now we get to the kitchen. A whole different story there. The walls were properly prepped before the wallcovering was installed. I know, I did it myself and went through the process step by step. But this kitchen is causing me sleepless nights. I have tried steam, vinager and scoring.. and still it taunts me with what seems like a demon like quality. I finally broke down and ordered the Wallwik removal system.. Anyone try that?? Did it work?
Thanks,
| It wasn't properly prepped if you can't get the wallpaper off now. I have heard good things about Wallwik, though have never tried it myself. It makes sense that it would work though because it saturates the paper and keeps it saturated. You can even make your own by simply soaking down the paper and then covering it with plastic sheeting. |
- Posted by christophern (My Page) on Wed, Feb 24, 10 at 5:35
| As painguy said, if it is not coming off it was not properly prepped.The wallwik will work well if you follow the directions. |
- Posted by helencolby (My Page) on Wed, Feb 24, 10 at 14:14
| Well now, I ended up contacting a lady that removes and hangs wallcovering for a living. She told me this. Sometimes even if the wall is properly prepped, it can be a pain in the duff to remove. But forget about scoring the covering.. Just take a razor and open up a corner of the wall covering and start to peel it away. It will leave the backing on the wall. But the top layer will peel away fairly easy. Do NOT wet it at this stage. Once we have the top layer off, then we can now spray water mixed with a bit of white vinager or fabric softener and begin to scrape down the bottom layer. It should come off easily. She said "If it went up with water, then it will come down with water.". She was absolutely right. I managed to peel off the entire kitchen in just over an hour. Now all I have to do is tackle the bottom layer. She told me about some of the so called strippable papers.. some are only strippable one layer at a time. And scoring only serves to weaken the top layer thus I won't be needing the Wallwik after all. Thanks for your replies. |
| Yeah, that is absolutely correct. You should always attempt to dry strip the top layer first. Just for fun, we should define what 'properly prepped' means because this has caused a whole lot of problems for a whole lot of people over the years and it has given wallpaper stripping such a bad rep where it really isn't deserved. Years ago, before drywall was around, everyone used sizing to prepare the walls for wallpaper. This worked great on plaster because plaster is hard as a rock. Then when the industry started using drywall, people still continued to 'size' the walls. Sizing is really the wrong thing to use for drywall. You should use a wallcovering primer, that is one that is designed for wallpaper to be hung on. Anyway, the clerks in paint stores continued to recommend to its customers that they use sizing for years and years because nobody educated them. Heck, even I used sizing until I somehow learned that was the wrong thing to use. These days thankfully, it is difficult to even find sizing on the shelves. So, the point of my story is that you very well could think that you have done the proper wall prep and could have been wrong, by no fault of your own. |
- Posted by helencolby (My Page) on Wed, Feb 24, 10 at 16:16
| What I used was Zinsser Shieldz to prep all the rooms that I hung wallcovering in. But the kitchen wallcovering was a totally different type than what I put in the other rooms.. and the most difficult. But now I have the top layer completely off and will start on the bottom layer on Friday. (Doctor dsy tomorrow). That saga is nearly over with, thank goodness, and I will now get it ready to paint. Paint is so much easier to replace. lol. Thanks bunches, |
- Posted by christophern (My Page) on Thu, Feb 25, 10 at 5:07
| Sorry for my initial response. I just assumed that you could not get the face of the paper off. Paintguy was also spot on in assessment of the industry. Sizing is (was) nothing but watered down GLUE( not like todays PASTE. Putting sizing on drywall was much worse than not priming and so as he said the industry has taken a beating and people hate wall covering for just that reason, it has been a nightmare to remove.As you are finding out, it is pretty simple with the proper installation. |
