| First off, why is there no "siding" section!,I never know where to post my siding questions :) Okay then, to the point. I am having vinyl siding put over my asbestos siding, and everyone keeps saying that I should be careful that the asbestos shingles will shatter when nailed through? What causes them to shatter? I don't get this, because they were nailed on to the house to begin with! I'm going to be getting a few estimates soon, so I also want to know what I should be looking for in a sider that is experienced with going over asbestos! Thanks :) |
| In dealing with houses with asbestos siding, the local Habitat for Humanity found it best to just remove the asbestos siding and then install rigid foam and vinyl siding. Asbestos containing shingle siding is extremely hard to begin with, age increases that hardness. The nails used to install it were most probably drilled at the factory or onsite. I can guarantee the existing siding will break when nailed from experience. |
- Posted by hollysprings (My Page) on Sun, Feb 3, 13 at 15:00
| Since you have extensive water damage from improperly flashed windows that will require removal of the siding down to the water damaged sheathing anyway. It's a false economy that would have you think that not going ahead and removing it all would actually be easier and cheaper to deal with when residing. You MUST remove the water damaged portions and replace them. In fact, it more labor (more $$) to try to make up the thickness difference between the existing siding and the areas around the windows that would need the siding removed and sheathing replaced in order to properly be flashed. That is assuming that there is a proper drainage plane of housewrap or roofing felt behind the existing siding. That's assuming a lot for a home of the era that is sided with asbestos. Most likely, that damage from the ongoing water penetration has destroyed most of the sheathing and insulation. It's also likely that there isn't a proper drainage plane in existence to begin with. That will need to be corrected in order for new siding to function properly. That means removing all of the existing siding. Back to square one. It's always cheaper to do the project correctly in the long run. |
| Asbestos cement panels should not be penetrated. Driving nails through is a definite NO-NO! Stop this contractor before they contaminate your property with asbestos dust! The old asbestos cement material had pilot holes drilled befroe fastening. Asbestos is too brittle to nail through directly. The workers were exposed to occupational asbestos hazards because they did not know the dust created during drilling and cutting was dangerous. |
- Posted by energy_rater_la (My Page) on Tue, Feb 5, 13 at 19:06
| what handymac said. nailing through asbestos siding will cause it to put an air barrier/vapor barrier on walls after if you have water damage as hollysprings says as asbestos shingles are OUTSIDE, you aren't best of luck. |
| "as asbestos shingles are OUTSIDE, you aren't contaminating anything. you can't get much more dillution than the great outdoors." This is NOT TRUE. Transite siding and roofing are a Regulated Asbestos Containing Material (RACM). Contamination is a big concern, outdoors or indoors. Here are the proper removal procedures for transite siding and roofing: 1. Place 6-mil polyethylene sheeting under the removal area to collect any debris. |
| The HfH chapter for which I volunteered used volunteers with long sleeved shirts, dust masks and gloves to remove asbestos shingles. With due care, this is a safe procedure. The plastic on the ground and the double bagging are necessary, as well as a applicable dumpster. Asbestos is dangerous because of the tiny fibers that make up the mineral asbestos. Those fibers are light enough to be easily airborne and inhaled. The fibers are mineral, so they never change, which causes the body's defenses to try and combat them. Airborne asbestos is called friable asbestos. The asbestos in siding is combined with adhesives which greatly reduce the friability factor. Making it much less dangerous with proper precautions. |
- Posted by energy_rater_la (My Page) on Wed, Feb 6, 13 at 19:20
| both of you are absolutely correct. my reply was totally incorrect. thanks to both aiden & handymac best of luck. |
