What to do about stained Victorian wallpaper?
lotusmoss (
Wed, Jan 16, 13 at 23:18
| We have a 1904 Victorian with lathe and plaster walls. As is typical in these homes, many of the ceilings are wallpapered with a sturdy wallpaper (name escapes me). We have been told by multiple people in the area historic home society, as well as realtors, that the wallpaper covers up the inevitable cracks in the plaster and in no situation should be taken down because it "keeps everything together". As you can see, there are some old water stains (no current moisture issues) on some of the wallpaper:
We've been told that this will be easily fixed with some Kilz or stainblocker. Does this sound about right? In other rooms, the wallpaper wasn't hung as well and the seams show and are coming apart in places, and the wallpaper glue has caused yellowing in places. The inspector for our house also encouraged to leave this up and said that if it bothered us, we could consider 1/8" drywall ceilings. Any advice on this? Or in the meantime, is there a way to "glue" down the seams before covering up the yellowing with Kilz or stainblocker? |
RE: What to do about stained Victorian wallpaper?
| You have been given a lot of crap advise(IMO). I have removed miles of paper in old homes and in most cases the walls and or ceilings were just fine. It was standard practice in the old days to paper everything, it's just what they did.Yes, SOMETIMES, it is covering up defects but usually nothing that cannot be dealt with. If you are going to paint over it( and big mistake IMO) use Zinnser orderless cover stain,Kilz oil just stinks too much. You need to find a new inspector ( 1/8 in drywall??) Again painting over the paper it nothing but a mistake and should never be done unless ABSOLUTELY necessary and this only happens on drywall, never plaster. |
| Hi christophern- it's good to have a second opinion. Just weird that we're getting such strong advice to leave it there from so many people on our end (Historic Homes, real estate folks, and inspector). I'm guessing you think that it's a big mistake to paint over the wallpaper because that would make it more difficult to remove the paper should the need arise at a later date? What would you do in this situation? Simply remove the wallpaper and paint the ceilings (and hope that the plasterwork is in good condition)? Thanks for any advice! |
| Hard to say from here but painting over it is never good. besides the part about future removal it just looks bad unless a lot of prep work is done first. I would remove the paper on one wall or ceiling and see whats up and go from there. |
Textured/patterned wallcovering like Anaglypta is intended to be painted. So obviously repainting it after shellacking the stains would be within the realm of reality, especially in light of the fact that it likely has already been painted. Casey |
| I think it's beautiful, and would want to preserve it. You can glue the edges back down with good wallpaper glue, shellac, and paint it. I would shellac the whole thing, because the shine can show through paint, and if the whole thing is the same sheen it will look better. That would be the cheapest and easiest thing to do. I believe spray painting is best, so that you don't get the paper soaked with paint. If you don't like the paper, and you don't think it adds value to the home, then by all means take it off. If the ceilings are badly in need of repair, it is not horribly expensive to drywall over the plaster. I am not a fan of 1/8" drywall on ceilings, though, since it sags and dimples when it is put on a ceiling, at least in my experience. In your area there may also be people who specialize in plaster repair, and you could find out what that might cost. I'm not particularly bothered by the look of cracks in real plaster myself, so I would not mind cracks if the plaster was in good shape otherwise. Good luck. |
| There is no contemporary wall paper GLUE. It is paste or adhesive, glue has not been used for 75 years or so. Where do you find 1/8 drywall??? "Anaglypta is intended to be painted." True, but that is not what I am seeing. |
| I meant 1/4" drywall. I don't think they make 1/8" drywall. Now that we have been properly put into our places on this topic, as well as the proper use of the word GLUE in relation to wallpaper, I might add that although it might sound reasonable to put thin drywall on a ceiling because it weighs less, the truth is that anything under 5/8" is not recommended for ceilings because it is not rigid enough and it can sag in the middle and dimple where it is attached. |
Everybody knows it's "wallpaper cement" ;) Casey |
| Lots of advice here! Looks like I need to get someone to look at it in person and see whether or not it is actually Anaglypta. In the living room (pictured above), the wallpaper was put up very well and so not a seam shows. In the other rooms, it is so stained and so bad at the seams that I'm very tempted to have it removed if it doesn't look like the plaster underneath is in horrible shape and make any minor repairs to the plaster needed before repainting the ceiling. We'll see though. It's good to know that very thin drywall can cause sagging issues. Sounds like we'll try and avoid that "solution" at all costs! Thank you all for your feedback! |
Properly prepared you can paint anything, including that ceiling. It will HAVE to be properly prepared or those water stains will make all the work for naught. I have a house full of painted wallpaper and if I had one piece of warning/advice it would be " what will you do if the paint removes the paper?" Odorless cover stain is a great reccomendation. Carry on. |
| "Properly prepared you can paint anything..." The problem comes if it is indeed cemented-glued whatever attached. The paint makes it that much harder to remove it. I have a rental house that idiot PO painted textured (flock type) wallpaper tat is on drywall. Whomever installed the paper did not prime either. I am NOT looking forward to trying to clean it up, and may end up just removing the drywall and replacing it (only in a not all that large a living-dining L area). |
| just removing the drywall and replacing sometimes thats all you can do to make it look right |
| Just as an FYI, we had a local anaglypta expert come out and check out the wallpaper. He said that it is anaglypta, and that it has been painted, and is paintable. He also said that he would use the odorless Bullseye primer and then would paint over. The thing is, he quoted us almost $1,000 to fix the seams of the paper in 1 room; and to caulk edges, prime, and paint in three rooms that don't need repair. That doesn't include any paint or materials! We are now hoping that we can take this project on ourselves now that we've heard from an expert that the anaglypta is basically in good shape and can be painted. That said, what is the procedure for this? We were thinking--gently moisten edges of anaglypta that are coming up and use wallpaper seam repair from a tube; gently use a brush (not seam roller) to get edges down. Let dry for 24-48 hours. And then for the rest of the ceilings, clean surface, caulk edges, prime and let rest for 48 hours, and then paint two coats with 24 hour dry times in between. Does that sound about right? Thanks for any advice! |
| Perhaps you could ask him what he would charge just to repair the wallpaper in that one room. It may not be easy to get the paper to stick to the ceiling long enough for the glue to dry. I imagine paper hangers have tricks for that. Stainblocker/primer first, then two coats, right? Are you going to spray or roll? I think spraying is recommended so that you don't get too much wet paint up there. |
| Put a coat of Gardz or oil primer first( before painting) |
I thought I'd just pop in to say that all of our walls and ceilings had multiple layers of wallpaper and we thought that it must be covering up damaged plaster. Wallpaper was just the fashion for many years. Our ceilings also had ceiling tiles, which further strengthened our idea that there was water damage. I removed everything and found beautiful plaster and a small area of damage that we easily fixed. Love our smooth plaster. Diane |
| You may also like to know there is an "old homes" forum on Gardenweb where you will likely find some of your kin. :) |
