JOIN NOW LOG IN
clarification on hydronic toe kicker heater
Posted by jtwindad (My Page) on
Wed, Jan 27, 10 at 8:15
Hi all,
New here. Just ripped out my kitchen and putting cabinets in. This means the radiator in the room is now gone. So I am going to use a toe kick heater. I am debating between hydronic (Turbonics 6/8) or an electric. I currently have radiators with a natural gas boiler. I live in Richmond, VA so it gets cold, but not that often. The house is 1950 brick on block construction - no insulation but I will be putting the pink styrofoam panels between the furring strips on the 2 outside walls, 2 windows - single pane no storm.
Originally I thought hydronic was a no brainer - just tie into the existing heater lines....until I talked to the guy at Turbonics - he said that the flow rate in my existing single line closed system is not enough for the kicker - it would cool to fast. I would have to add another circulator pump (Taco 006) at the boiler and run new lines for it's own system. This just got more complicated and expensive!!! The boiler is also about a 40 feet total run from where the kicker will be. So I am looking at a new pump, 100' pex (supply and return), and what ever check valves and such that I need... Really making electric sound easier and cheaper. The room is 14x11 and our stay in this house is 5-7 years max. What to do?
Thanks,
Joe
RE: clarification on hydronic toe kicker heater
In the long run the electric will cost more, the boiler is already hot and heating
It depends on how often you use it and the cost of electricity.
In Richmond, you'd be crazy to choose electric.
