Return to the Quilting Forum
squaring up disappearing nine patch
loralee (
Sun, Dec 2, 12 at 20:40
| I have my first block sewed together. Do I square this block up now or cut it into the 4 pieces and sew them back together and then square it up. The block is off just a tiny bit. Thanks |
RE: squaring up disappearing nine patch
| I would cut then square it up. beverly |
| This works for me as the block is now 14" square and I do not have a ruler large enough with the diagonal line large enough to square up a block this size. |
| As I don't consider it a finished block until it is cut and resewn I would wait.MHO |
| I square up the 4 pieces to make sure they're all the same size then sew them together. I'm in the process of making one, too. SharonG/FL |
| I have decided I will sew the 4 pieces together and then square up. I guess there is no right or wrong way to do this as long as each block comes out square in the end. Thank you for your input on this. |
