Wed, Oct 3, 12 at 22:05
| I think I posted here that I was planning on making a quilt for my Granddaughter out of her sleepers. I find that the light interfacing that I am using to stabilize the 4" blocks for the quilt makes the fabric stiffer than the sleepers which I guess is to be expected. I washed one 4" square after I iron on the interfacing and it was much softer.
I'm not sure what to do unless I wash all of it after the interfacing has been put on or try to find a featherweight interfacing. Also how do you clean your cutting mat? |
| Maet, you will want to wait until the quilt is finished to wash it. I may be reading it wrong but it sounds like you're talking about fusing the squares then washing them before sewing. I don't know what type of interfacing you're using, but the knit kind is very soft even after fusing. I don't know about cleaning the cutting mat - I can't recall ever needing to clean mine except for wiping off the fuzzies stuck in the little cuts. Donna |
| Thanks Donna, I think I will wait and have a look for the knit interfacing. I was talking about washing the 4" squares that I have already ironed interfacing on, about 20 squares. |
- Posted by murphy_zone7 (My Page) on Fri, Oct 5, 12 at 4:48
| one way to clean those "fuzzies" out of your mat is to use a scrubbie....like nylon net, or those bath pouf things. Also can use a art gum eraser and it will get them out. Hope this helps. |
Return to the Quilting Forum
