Return to the Quilting Forum
Help Piecing Border
csackett (
Sat, Sep 8, 12 at 21:53
| I had to cut strips for my quilt border and will have to sew them together to make them long enough. Should I just sew the ends together or sew them with a diagonal seam together. |
RE: Help Piecing Border
| Either method works but the diagonal is the more traditional/accepted method. I will admit I've done it both ways. I used to think the diagonal was harder and took longer but once I started doing it I discovered it was just as easy. Diagonal does make for flatter seams and they say it's stronger as well. Really though, non-quilters will never notice. It's up to you. Kate |
| I've done it both ways, too. Something to consider is the fabric....solid or print? A print usually doesn't show a straight seam but I like to use diagonal with solid...not that I always do....depends on how much fabric I have. Not much help, eh? SharonG/FL |
| I think the diagonal seam is less noticeable. Of course, if the border is a stripe or directional fabric, you want to take extra care that everything matches up just so. Teresa |
| I think it depends on the width of the border. A diagonal seam on a wide border is going to be longer than a straight seam. |
| Good point! On stripes I use a straight cut not a diagonal. |
| I base it on width, too. If the border is over 3" wide I use a straight seam, usually diagonal for narrower ones. Donna |
