half square triangles
Posted by buteau3rd (My Page) on
Sat, Sep 17, 11 at 19:16
Has anyone ever tried using the paper printouts from "Quilting and Whatnot"?
They were so, so easy and absolutely perfect.
When I looked at the lines, .I really didn't think it was correct, because there were no corner to corner cutting lines. They looked a bit askew to me.
They are the best, easiest ones I have ever made
RE: half square triangles
Isn't that the same thing that Vicky was using for her tree quilt? I would have to go back in the posts and find it but if it wasn't this one, it was close. I couldn't believe how quick and easy it was to make a bunch of perfect HST!
Kate
Here is a link that might be useful: half square triangle pattern
It's a different one
I was wrong. Vicky's was similar but not exactly the same.
Here is a link that might be useful: HST pattern
As a newbie, I'm wondering how one uses these patterns? Do you just do a few at a time?
Kate, the first one is the one I was talking about. If you compare them, the second one is the one I have always used, and you do cut corner to corner. The one from quilts and whatnot has no corner to corner cuts but they are perfect!
Now I am really curious as to
vickies pattern!
Casi, half square squares are used very often in quilts. It depends on your pattern, some are almost all HSTs..........very versatile.....you can do so much with them.
Hope you enjoy quilting with us.
I love this forum, everyone is very helpful. I have been having trouble with my HST's...trying to figure out how ones uses the patterns. Print off mulitple copies and then place on fabric??
I get really annoyed trying to get the paper pieces off so I just make mine 7/8 larger than the finished HST and trim to size.
I am going to print the diagram out and try it.
Rosa
I use a very small stitch, and fold on the stitch line and it was like "tear on the dotted line".
Also I do all the rotary cutting between the squares first.
I print one copy then stack plain paper with it and sew along the stitch lines without thread. I'll do a stack of 10 pages at a time, using an old needle of course. Then when i use a page it gets sewn through the second time. Makes tearing the paper off very easy!
I've read that using news print paper works great too.
Thank you for that link! I've bookmarked that page.
Karlene
Kay, I like the way you think! My printer runs out of ink more often than I like. I did think of newspaper, but haven't tried it yet. Did anyone else check the QUILTS AND WHATNOT layout for the HSTs? Am I the only one that thought it looked wonky!
I looked at it too. It may print true even if it looks odd on your computer. It may depend on how your monitor screen resolution is set.
Kate
There is a lot of paper piecing on the Dear Jane I'm working on and found that vellum paper works great. It's thin and tears really easy after you stitch through it and it goes through the printer very easily.
Robbi
Robbi, have you tried baking parchment paper? It is less expensive then vellum and I believe it works as well. I am not a PP at heart but like the parchment.
Newspaper is what the old timers used because it was available. I've used it in the past for a few projects. It's not bad to work with.
Return to the Quilting Forum
