Help, I'm Math Challenged
Posted by geezerfolks (My Page) on
Fri, Sep 16, 11 at 9:58
I went online to print off some graph paper for the Blooming 9-Patch to get started on a colorway. I found squares, diamonds, ect, but what's the math term for squares on point? I finally ended up cutting the one with squares and making my own. Surely there's one somewhere but I just don't know what to call it. I know someone here will know.......thanks.
SharonG/FL
RE: Help, I'm Math Challenged
Try this link! Printable, on-line graph paper in my shapes and sizes. I think the one you want is called axonometric.
Let me know if that's not right!
Kate
Here is a link that might be useful: Axonometric Graph Paper
You'll get something that looks similar to this if you set the 'side line size' to 0.3 inches and click on both 'horizontal' lines and 'vertical' lines. You can get rid of the h & v lines completely, leaving only the diamonds and you can set the side line size however you want. 0.5 inches gives you pretty big diamonds.
Kate
That's a great resource, Kate. Thanks.
Thank you, Kate. That's what I needed! I'll print it out when I get on the desktop. I print out the graphs I use, put them in a clear protector sheet and then just make copies when needed instead of having to go online and print them off. You have made me a happy camper!!!!
SharonG/FL
I only opened this thread out of curiousity.....it's not as if I can help you at all.......:(
Teresa, who is also math challenged herself
I'm happy to help! I try to use my powers for good, not evil.
Kate (aka TechnoTwinkie)
Return to the Quilting Forum
