quilting holes ?
Posted by littlehelen (littlehelen@comcast.net) on
Thu, Aug 8, 13 at 17:26
I quilted a small project and after one section was complete...I hated it...so I ripped out the quilting. Now I'm left w/ itsy bitsy needle holes in the fabric. (My error, in I didn't check my stitch size...dumb I know) Anyway, I pressed the fabric, but it's still apparent the area was quilted. Not sure if I should just proceed with quilting the area, or just what to do. I'm concerned when I quilt the area again the marks will still show...Suggestions...thoughts?
V.
RE: quilting holes ?
My experience is that those holes will disappear when the quilt is washed.
If you don't intend to wash it, then rubbing a fingernail across the hole may convince it to go away.
hth
Yes, what Jennifer said. :-)
SharonG/FL
Mist it very slightly with water, and rub with a soft brush - clean toothbrush.
This will close up the weave where the needle and thread went thru. If the stitches were too close (too small) it may take a few gentle times.
You said you pressed the fabric-did you press it as a sandwich with the batting in the middle? Misting will help soften and relax the weave/fibers. Be gentle so not to distort the piece.
Don't press the holes open into place.
I use a lot of safety pins when hand-quilting the layers together which leaves noticeable holes, so I usually use my fingernail to rub them out and then after I complete the quilt I wash it before giving it away and after that the holes are gone.
Best to you,
Sandra
thank you all for the ideas...I did mist the fabric (it was sandwiched) and then pressed, but did not think of the gentle brushing...good idea, will give it a try.
I did not intend to wash this piece; however, I think that may take care of the issue.
V.
you should a lot of safety pins when hand-quilting the layers together which leaves noticeable holes.
Return to the Quilting Forum
