qotd
Posted by nanajayne (My Page) on
Mon, May 14, 12 at 19:55
I am about to put on a quilt binding and was wondering how others apply theirs.
Do you mark the border-sew on the binding then trim before you turn to the other side?
OR
Do you trim the border-sew on the binding and turn?
I usually trim before I apply the binding except when I am doing curved edges but can see advantages to doing it the other way.
RE: qotd
I used to always sew the binding then trim the edge. I think I thought it helped make sure that all three layers of the quilt were sewn in the seam.
For my last few quilts (some big ones and a bunch of minis) I've trimmed the edge first in order to make sure the border is straight and the corners square. I've been a lot happier with the results.
Donna
RE: qotd
I do it both ways depending on the quilt. The one I'm finishing now, I marked where the edge was to be with a pen, sewed on the binding, then trimmed. I use the Sharon Schamber glue method so it gets pressed before the actually stitching. I think it makes it all lay much flatter and keeps the edges all together through the process.
RE: qotd
I trim, sew, fold. I've not done a curved border yet, so that may change.
beverly
RE: qotd
I have always trimmed first to square up edges and corners, then sewn & folded to the back.
RE: qotd
I always sew first, trim and then turn. I do lots of curved borders on my quilts and don't seem to have any more difficulty sewing the seam straight than I would cutting it. Actually less and that's why I do it that way.
RE: qotd
I always trim first than add the binding. The only curved bindings I have done were the DWRs. The long-arm quilter stitched around the edge so I trimmed before binding on those quilts also.
Linda OH
RE: qotd
I baste with really big stitches and then trim. I like thin bindings and I use glue, it makes the mitered corners so much easier to do. It amazes me how people come up with these ideas lol!!!
Rosa
RE: qotd
I have tried marking where I would normally trim, and using that line to guide the serger.
Then using that quarter inch (made by serging) for stitching my binding on. It feels neater. Also controls any stretchiness if needed.
RE: qotd
I have done it both way but I usually sew first, then trim.
Vicky
RE: qotd
On many of my smaller quilts I have serged the binding on but I usually trim before, even though the serger smooths the edges. I like the serged method, much quicker and the results are satisfactory, but I still hand stitch it down.
RE: qotd
I always trim first. It never occurred to me to do it any other way and I've never done a curved binding.
RE: qotd
Like Lola, it never occurred to me to do anything else but trim first, then sew. If I'm worried about keeping the edges in line, I have basted first. And I always use my walking foot to keep the layers from sliding while I sew on the binding.
RE: qotd
I'm going to show my ignorance - when you say 'trim the border' do you actually mean trim the border or trim the batting/backing?
Karlene
RE: qotd
I have done it both ways but prefer trimming first. I have lopped off a few mitred corners when trimming after sewing.
Theresa
RE: qotd
Karlene, trim the sandwich to make sure the edges are all even to fill the binding. Usually that means the batting and the backing BUT as much as I square up as I go, sometimes my sandwich is off a little and I have to square it up.
I don't trim the corners until I get to the point of glueing them down and sewing them to the back. I have trimmed them to close before lol!!!!
Rosa
RE: qotd
Glue down? Please explain further. I am not familiar with this. Do you mean actual glue? Ok, stop giggling. I really do not know.
Nancy
RE: qotd
I've never heard of using glue either and would love an explanation!
I have only one method: trim, sew and turn to the back to sew by hand. But I haven't done any curved or shaped edges.
Kate
glue tutorial?
Is this the glue method you all use? When I read about gluing I thought you were gluing the sandwiched layers together at the edges. This tute makes more sense than what I was thinking! But it seems like a lot more work than just sewing and turning.
Here is a link that might be useful: Glue Binding Tutorial
RE: qotd
Here is another of Sharon Schamber videos ~ watch all 3. I had never seen these before.
I don't use glue, but maybe I will on my next quilt. I know glue has been mentioned often when binding.
To answer the question-I've tried both methods - trimming after the binding is attached - Sally Collins likes this method. It depends on the quilt, because I square the quilt before I sew on the binding, but sometimes I trim again. I like small bindings.
Here is a link that might be useful: Binding use Glue method
RE: qotd
I sew it to the front, trim, then hand-sew to the back. I use the walking foot to sew it on the front.
RE: qotd
Thank you for the clarification! I also sew it to the front and then trim the batting/backing and hand-sew to the back.
Karlene
RE: qotd
I watched all three videos this morning. I will try that when I bind the quilt I am working on. It did look a lot smoother. Thanks ladies for all of your help. Nancy
Return to the Quilting Forum
