Return to the Quilting Forum
Binding tip
fran1523 (
Mon, Mar 11, 13 at 16:57
| You may already be aware of this but it's a great tip for those who don't. When you are hand sewing the binding to the back of a quilt, if you run the needle and thread through a fabric softener sheet three or four times, the thread will hardly ever tangle and you can use a much longer piece. |
RE: Binding tip
I didn't know that! I have two that I need to add binding to and will give it a try. Thanks, Fran! Sue |
RE: Binding tip
| I hadn't heard that either. Thanks for the tip. |
RE: Binding tip
| News to me. Have always used "quilter heaven" but this sound easier. TFS. |
RE: Binding tip
| Fran, that's a good tip. I also use Thread Heaven. I also prefer using shorter pieces of thread so there is less to re-sew if a section happens to come undone over time. :) Donna |
RE: Binding tip
I never heard of this either, but when you think about it, it makes sense. Thanks for sharing! V. |
RE: Binding tip
| Wow! I've never heard of this either. Thanks so much for sharing; it saves me mucho frustration. :-)) |
RE: Binding tip
| Thanks for the tip. I have a binding to sew this week. This will keep my sailor's cussing at a minimum. |
RE: Binding tip
| Donna, you can have the best of both worlds. When hand stitching something, I use as long a thread as I can handle, but periodically tie a knot and snap it through, then continue on. |
RE: Binding tip
| Thanks, Donna! I try to remember to do that, but often forget. :) Donna |
RE: Binding tip
Great tip! Thanks Darlene |
RE: Binding tip
| Thanks for the tip. I will also give it a try. |
